StarTech.com USB-C to VGA Adapter - White
Quicklinx: BJX1WS00 Mfr#: CDP2VGAW
£21.61 ex VAT
£25.93 inc VAT
Connect your MacBook, Chromebook or laptop with USB Type-C to a VGA monitor or projector. This USB-C to VGA video adapter lets you output high-definition VGA video from your USB Type-C device.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. The connector is featured on ultra-portable devices with USB 3.1 Gen 1. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the MacBook and Chromebook Pixel . It's also compatible with Thunderbolt 3 ports.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your MacBook or Chromebook, because it fits easily into your laptop bag or carrying case. This ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you take advantage of the versatile USB Type-C port on your portable device. The USB Type-C connector is reversible, so no matter how you plug it in, the adapter will always work, which saves you the hassle and embarrassment of struggling with your device when you're trying to deliver a presentation or collaborate with a colleague.
The adapter supports video resolutions up to 1920x1200 or 1080p. You'll be surprised at the picture quality the adapter provides, even when connected to a legacy VGA monitor, projector or television. The adapter harnesses the video capabilities that are built into your USB Type-C connection, to deliver every detail in stunning high-definition.
The CDP2VGAW features a white housing that looks great with your MacBook.
Your USB-C equipped device must support video to work with this adapter. The adapter will not output digitally encrypted content.
StarTech.com USB-C to VGA Adapter - White - 1080p - Video Converter For Your MacBook Pro / Projector / VGA Display (CDP2VGAW) - USB / VGA adapter - 24 pin USB-C to HD-15 (VGA) - 17.5 m
USB / VGA adapter
USB power, 1920 x 1200 (WUXGA) support, DisplayPort Alternate Mode support
Length
17.5 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
15 pin HD D-Sub (HD-15) - female (output)
USB 3.1 Gen 1 / Thunderbolt 3
White
3-year warranty
P/N: TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
USB / VGA adapter
Length
17.5 m
White
3.5 cm
1.6 cm
23 g
Connector
USB 3.1 Gen 1 / Thunderbolt 3, FCC, RoHS
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Height
1.7 cm
Shipping Weight
31 g
3-year warranty
BJX1 StarTech.com USB-C to VGA Adapter In Stock £23.74
BJX1 StarTech.com USB-C to VGA Adapter - White In Stock £21.61
BJX1 StarTech.com USB-C to HDMI Adapter In Stock £22.69
BJX1 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £32.27
BJX1 StarTech.com 6ft USB-C to DisplayPort Cable In Stock £28.80
BJX1 StarTech.com 2m USB-C to DVI Cable In Stock £24.14
BJX1 StarTech.com 2m USB-C to HDMI Cable In Stock £31.44
BJX1 StarTech.com USB-C to VGA - Power Delivery In Stock £23.19
BJX1 StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £16.82
BJX1 StarTech.com 1m USB-C to VGA Cable In Stock £28.51
BJX1 StarTech.com USB-C to HDMI - Power Delivery In Stock £25.73
BJX1 StarTech.com USB-C to DisplayPort Adapter In Stock £23.87
BJX1 StarTech.com USB-C to HDMI Presentation In Stock £40.26
BJX1 StarTech.com USB-C to DisplayPort Adapter In Stock £23.09
BJX1 StarTech.com USB-C to DVI with USB PD In Stock £17.71
BJX1 StarTech.com USB-C to DP with USB PD In Stock £31.36
BJX1 StarTech.com 1m USB C to DP Cable - White In Stock £24.72
BJX1 StarTech.com 6 ft USB C to DP Cable - White In Stock £28.24
BJX1 StarTech.com 3m USB C to DisplayPort Cable - White In Stock £30.46
BJX1 StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £32.46
BJX1 StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £26.59
BJX1 StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £32.54
BJX1 StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.36
BJX1 StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £25.52
BJX1 StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £23.00
BJX1 StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £24.71
BJX1 StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £27.49
BJX1 StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £29.45
BJX1 StarTech.com Portable USB C to HDMI Adapter with Keychain In Stock £18.81
BJX1 StarTech.com Portable USB C to VGA Adapter w/ Keychain In Stock £10.42
BJX1 StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £32.41
BJX1 StarTech.com USB C to DP Adapter - 8K/4K In Stock £23.32
Stock Status: While stocks last
Stock Status: Clearance
