StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable
Quicklinx: FM8MWS00 Mfr#: CDP2DP2MBD
Length: 2m
£16.97 ex VAT
£20.36 inc VAT
USB Type-C Adapter Cable 4K 60Hz Thunderbolt 3 . This USB-C to DisplayPort 1.2 cable lets you connect your USB Type-C (or Thunderbolt 3 ) device to a DisplayPort display, or a DP device to a USB-C display with just one cable.
Easy & Clutter-Free Installation
At 6.6 ft. (2 m) in length, this bidirectional adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation. For shorter installations, we also offer a 3.3 ft. (1 m) USB-C to DP cable, enabling you to choose the right cable length for your custom installation needs.
As well, the cable works with both Mac and Windows devices and allows for plug-and-play installation, removing the need for any additional software or drivers.
Convenient, Bi-Directional Support
Use this USB-C to DisplayPort adapter cable to output 4K video and audio to a DP display from the USB Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities, this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input.
Ultra HD 4K Resolution at 60Hz
This USB-C to DP 1.2 adapter cable lets you harness the video capabilities that are built into your computer's USB Type-C (or DisplayPort) connection, to deliver the astonishing quality of UHD to your 4K display. For even higher resolution and bandwidth support, we offer a USB-C to DP 1.4 cable, which is the perfect accessory for early adopters of 8K.
CDP2DP2MBD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
Note: Your USB 3.1 Type-C device must support DP Alt Mode to work with this cable.
  • Easy & clutter-free installation
    This?bi-directional adapter cable delivers a compact?connection that eliminates excess adapters and cabling,?ensuring?a tidy, professional installation.
  • Convenient support
    Use this USB-C to DisplayPort adapter cable to output video and audio to a DP display from the USB Type-C (or Thunderbolt 3) port on your laptop or mobile device. With bi-directional capabilities, this cable can also connect your DisplayPort-enabled devices to a display featuring USB-C input.
StarTech.com 6ft (2m) USB C to DisplayPort 1.2 Cable 4K 60Hz, Bidirectional DP to USB-C or USB-C to DP Reversible Video Adapter Cable, HBR2/HDR, USB Type C / Thunderbolt 3 Monitor Cable - 4K USB-C to DP Cable (CDP2DP2MBD) - DisplayPort cable - 24 pin USB-C to DisplayPort - 2 m
DisplayPort cable
4K support, active cable, DisplayPort Alternate Mode support, bidirectional
Length
2 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
20 pin DisplayPort - male (output)
USB 3.1 / Thunderbolt 3 / DisplayPort 1.2
3-year warranty
DisplayPort cable
Length
2 m
Connector
3-year warranty
FM8M StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.38
FM8M StarTech.com 6in Mini DisplayPort to DisplayPort Video Cable Adapter - M/F In Stock £8.54
FM8M StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.80
FM8M StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £11.44
FM8M StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.89
FM8M StarTech.com 10ft USB-C to DP Adapter Cable In Stock £19.49
Length: 2m
