StarTech.com USB-C to VGA, DVI or HDMI
Quicklinx: CY2LWS00 Mfr#: CDPVGDVHDBP
£38.72 ex VAT
£46.46 inc VAT
This USB-C multiport adapter offers a portable solution for connecting your USB-C computer to a VGA, DVI or HDMI display. The adapter combines multiple video outputs into a single adapter, for an all-in-one connectivity solution. This adapter only connects to one display at a time.
  • All-in-one video?connectivity, with?travel in?mind
    Avoid the hassle of carrying different adapters for different displays with this 3-in-1?USB-C adapter. With VGA, DVI and?HDMI?output, you can connect your laptop to virtually any display.
  • Astonishing?picture quality
    The HDMI?output?on this?USB-C video?adapter?supports?UHD 4K resolutions,?providing four times the picture quality of high-definition 1080p.?All of?the outputs (HDMI, VGA, DVI) can support high-definition resolutions of up to 1920 x 1200.
  • Maximum?portability
    The convenient plug-and-play?USB-C dongle?is?the perfect?travel accessory. Fitting easily into your laptop bag,?and offering three video output options,?the USB-C display adapter is?an ideal?solution for Bring Your Own Device (BYOD) applications, wherever you go.
StarTech.com 4K USB C to HDMI, VGA & DVI Multi Port Video Display Adapter for Mac / Windows Laptop & Monitor (CDPVGDVHDBP) - adapter - HDMI / DVI / VGA / USB - 15 cm
Cable
Adapter - HDMI / DVI / VGA / USB
Max Output Resolution
3840 x 2160 - 30 Hz
Length
15 cm
Connectors
24 pin USB-C - male (input)
Connectors (Second End)
HDMI - female (output) , HD-15 (VGA) - female (output) , DVI-I - female (output)
Displayport 1.2/Thunderbolt 3
Active converter, 4K30Hz (3840 x 2160) support (HDMI), 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA)
3-year warranty
Cable Type
Adapter active converter, 4K30Hz (3840 x 2160) support (HDMI), 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA)
Interface Supported
Length
15 cm
DisplayPort Alternate Mode support, 7.1 channel Surround Sound
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Connectors
19 pin HDMI Type A - female (output) , 15 pin HD D-Sub (HD-15) - female (output) , 24+5 pin combined DVI - female (output)
FCC, RoHS
4.5 cm
8.5 cm
1.5 cm
51 g
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Height
2 cm
Shipping Weight
55 g
Limited warranty - 3 years
CY2L StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
CY2L StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Silver Aluminum Adapter - 4-in-1 USB-C Converter (CDPVGDVHDMDP) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £23.16
CY2L StarTech.com USB-C Multifunction Adapter In Stock £47.42
CY2L StarTech.com USB-C Adapter - PD - Silver In Stock £47.42
CY2L StarTech.com USB C Adapter - 4K HDMI, GbE In Stock £26.04
CY2L StarTech.com USB-C to VGA, DVI or HDMI In Stock £38.72
CY2L StarTech.com USB C VGA Multiport Adapter In Stock £36.98
CY2L StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB In Stock £37.45
CY2L StarTech.com USB C to VGA and HDMI Adapter - Aluminum - USB-C Multiport Adapter - 6" Built-In Cable In Stock £28.26
CY2L StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £19.36
CY2L StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD In Stock £12.85
CY2L StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter In Stock £30.67
CY2L StarTech.com USB C Multiport Video Adapter - HDMI or Mini DisplayPort -HDR 4K Display Adapter In Stock £16.09
CY2L StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock In Stock £23.20
CY2L StarTech.com USB C Multiport Adapter 4K In Stock £32.06
CY2L StarTech.com USBC Multiport Adapter 4K HDMI In Stock £27.08
CY2L StarTech.com USB-C Multiport Adapter HDMI In Stock £51.79
CY2L StarTech.com USB C Multiport Adapter In Stock £16.61
CY2L StarTech.com USB C to HDMI Adapter 4K 60Hz In Stock £12.35
CY2L StarTech.com Multiport Adapter HDMI/VGA In Stock £21.73
CY2L StarTech.com USB C Multiport Adapter, 4K In Stock £32.53
CY2L StarTech.com USB C Multiport Adapter 4K In Stock £25.41
CY2L StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £33.64
CY2L StarTech.com USB C Multiport Adapter 2 HDMI In Stock £65.89
CY2L StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £30.58
CY2L StarTech.com USB-C Multiport Adapter In Stock £22.04
CY2L StarTech.com USB C Multiport Adapter In Stock £82.76
CY2L StarTech.com USB-C Multiport Adapter, HDMI In Stock £32.62
CY2L StarTech.com USB-C Multiport Adapter, HDMI In Stock £28.89
CY2L StarTech.com USB-C Triple Monitor Docking Station In Stock £146.41
CY2L StarTech.com USB-C Multiport Adapter - HDMI/DP In Stock £43.75
CY2L StarTech.com USB-C Multiport Adapter - HDMI/VGA In Stock £27.87
CY2L StarTech.com USB-C Speakerphone Dock In Stock £78.85
CY2L StarTech.com USB-C Triple-Monitor Adapter In Stock £87.62
CY2L StarTech.com USB-C/USB-A Multiport Adapter In Stock £53.69
CY2L StarTech.com USB-C Triple-Monitor Adapter In Stock £91.75
