StarTech.com USB C to USB Transfer Cable - 2m
Quicklinx: DHP4WS00 Mfr#: USBC3LINK
Length: 2m
Hurry, only 2 left in stock!
£26.79 ex VAT
£32.14 inc VAT
Quickly transfer your Windows or Mac files to your USB-C enabled laptop or desktop computer. Transfer files from your old computer to your new USB-C enabled laptop or desktop computer, quickly over USB 3.0. This data transfer cable is easy to use and works with both Mac and Windows.
The transfer cable saves you time and effort when you're upgrading from a USB-A computer to your new USB Type-C computer. You can quickly transfer your files and settings over USB 3.0, also known as USB 3.1 Gen 1, with file transfer speeds up to 5Gbps. There's no CD or download required - the software is stored on the cable so you're ready to go.
As you're setting up your new computer, the USB 3.0 transfer cable offers wide compatibility letting you transfer files between two computers including Windows to Windows transfers, Windows to Mac, Mac to Windows, and even Mac to Mac transfers.
The cable is compatible with Windows Easy Transfer software for migrating to a newer version of Windows, up to Windows 8 (Windows 8.1 does not support data transfer cables.). The PCLinq software, stored on the cable, allows file transfers in any direction between any compatible OS, with no CD or download required.
The transfer cable comes in a convenient 2 m length for ease of use.
  • Save time setting up your new computer
  • Compatible with Mac and PC
    As you're setting up your new computer, the USB 3.0 transfer cable offers wide compatibility letting you transfer files between two computers including Windows to Windows transfers, Windows to Mac, Mac to Windows, and even Mac to Mac transfers. The cable is compatible with Windows Easy Transfer software for migrating to a newer version of Windows, up to Windows 8 (Windows 8.1 does not support data transfer cables.). The PCLinq software, stored on the cable, allows file transfers in any direction between any compatible OS, with no CD or download required.
  • Easy to use
    The transfer cable comes in a convenient 2 m length for ease of use. The USBC3LINK is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB C to USB Data Transfer Cable for Mac and Windows, USB 3.0 - 2m (6ft) - USB-C cable - 24 pin USB-C to USB Type A - 2 m
USB-C cable
5 Gbps data rate
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
USB-C cable
5 Gbps data rate
Length
2 m
Connector
24 pin USB-C - male
USB 3.0, FCC, RoHS
DHP4 StarTech.com USB 3.0 Data Transfer Cable In Stock £33.93
Length: 2m
