Quickly and easily transfer all of your Windows or Mac files to your new computer. Here's an easy way to transfer files from your old computer to your new one. This data transfer cable lets you move files quickly over USB 3.0, and works with both Mac and Windows.
The transfer cable saves you time and effort when you're upgrading to a new computer. You can transfer your files and settings quickly over USB 3.0, also known as USB 3.1 Gen 1, with file transfer speeds up to 5 Gbps. Plus, there are no additional drivers to install when connecting your computers, because the necessary software is stored on the cable.
The data transfer cable supports a wide range of operating systems, working with Windows and Mac. The USB 3.0 transfer cable lets you transfer files between two computers including Windows to Windows, Windows to Mac, Mac to Windows, and even Mac to Mac.
The data transfer cable is compatible with Windows Easy Transfer software for migrating to newer versions of Windows, up to Windows 8. Plus, the built-in PCLinq software also allows file transfers in any direction between compatible operating systems, including Windows 10.
The USB3LINK data transfer cable comes in a convenient 2 m (6 ft.) length.
Save time setting up your new computer
The transfer cable saves you time and effort when you're upgrading to a new computer. You can transfer your files and settings quickly over USB 3.0, also known as USB 3.1 Gen 1, with file transfer speeds up to 5 Gbps. Plus, there are no additional drivers to install when connecting your computers, because the necessary software is stored on the cable. -
Wide compatibility with Mac and PC
The data transfer cable supports a wide range of operating systems, working with Windows and Mac. The USB 3.0 transfer cable lets you transfer files between two computers including Windows to Windows, Windows to Mac, Mac to Windows, and even Mac to Mac. The data transfer cable is compatible with Windows Easy Transfer software for migrating to newer versions of Windows, up to Windows 8. Plus, the built-in PCLinq software also allows file transfers in any direction between compatible operating systems, including Windows 10. The USB3LINK data transfer cable comes in a convenient 2 m (6 ft.) length, and is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com USB 3.0 Data Transfer Cable for Windows & Mac - 2m (6ft) - direct connect adapter - USB 3.0 - USB 3.0
- Direct connect adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- USB 3.0
- Length
- 1.85 m
- 77 g
- Data Link Protocol
- USB, USB 2.0, USB 3.0
- Data Transfer Rate
- 5 Gbps
- Processor
- Prolific PL-27A1
- USB 1.1, USB 2.0, USB 3.0
- Black
- System Requirements
- Microsoft Windows Vista / 7 / 8 / 8.1, Windows 10 (32/64 bits), Apple MacOS X 10.7.5 - 10.10
- 2-year warranty
- Form Factor
- External
- Ports
- USB 3.0
- Connectivity Technology
- Wired
- USB, USB 2.0, SuperSpeed USB 3.0
- 5 Gbps
- Status Indicators
- Link/activity
Processor / Memory
- Processor
- Prolific PL-27A1
- 1 x USB 3.0 - 9 pin USB Type A - male
- MTBF
- 500,000 hour(s)
- FCC, RoHS
- Black
- Software Included
- PC-Linq
- OS Required
- Length
- 1.85 m
- 77 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 85%
StarTech.com USB C to USB Transfer Cable - 2m | In Stock | £25.61 |
