StarTech.com USB-C to HDMI Adapter
Quicklinx: BTLZWS00 Mfr#: CDP2HDW
£16.89 ex VAT
£20.26 inc VAT
Connect your MacBook, Chromebook or laptop with USB-C to an HDMI display or projector. This USB-C to HDMI adapter lets you output HDMI video and audio from a USB Type-C device such as a MacBook or Chromebook laptop. This adapter works with USB-C devices that pass a DisplayPort video signal. It's also compatible with Thunderbolt 3 ports.
This USB type-C video adapter is highly portable with a small footprint and lightweight design. The adapter is the perfect accessory for your MacBook or Chromebook, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving you the hassle and embarrassment of fiddling with your device when you're trying to deliver a presentation.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. The adapter lets you harness the video capabilities built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
The CDP2HDW features a white housing that looks great with your MacBook.
Note: Your USB-C equipped device must support video to work with this adapter.
StarTech.com USB C to HDMI Adapter - 4K 30Hz - USB 3.1 Type-C to HDMI Adapter - USB-C to HDMI Dongle - Monitor Adapter - White (CDP2HDW) - external video adapter - white
External video adapter
Bus Type
USB-C
Graphics Engine
- up to
Max Resolution
3840 x 2160
Interfaces Details
HDMI
Enclosure Colour
White
3-year warranty
P/N: TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Bus Type
USB-C
Max Resolution
3840 x 2160
Interfaces Details
HDMI
USB powered
Video Input
USB powered
FCC, RoHS
Enclosure Colour
White
Limited warranty - 3 years
BTLZ StarTech.com USB-C to HDMI Adapter In Stock £19.31
BTLZ StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £13.10
BTLZ StarTech.com 6ft USB-C to DisplayPort Cable In Stock £23.07
BTLZ StarTech.com 2m USB-C to DVI Cable In Stock £24.22
BTLZ StarTech.com 2m USB-C to HDMI Cable In Stock £29.19
BTLZ StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £16.30
BTLZ StarTech.com USB-C to DisplayPort Adapter In Stock £22.55
BTLZ StarTech.com USB-C to HDMI Presentation In Stock £14.12
BTLZ StarTech.com USB-C to DisplayPort Adapter In Stock £20.76
BTLZ StarTech.com USB-C to DP with USB PD In Stock £16.26
BTLZ StarTech.com 1m USB C to DP Cable - White In Stock £9.59
BTLZ StarTech.com 6 ft USB C to DP Cable - White In Stock £26.09
BTLZ StarTech.com 3m USB C to DisplayPort Cable - White In Stock £12.80
BTLZ StarTech.com 3m USB C to DisplayPort Cable - Black In Stock £19.74
BTLZ StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £16.59
BTLZ StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £20.05
BTLZ StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £19.01
BTLZ StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable In Stock £18.05
BTLZ StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K In Stock £24.08
BTLZ StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? In Stock £19.97
BTLZ StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable In Stock £22.35
BTLZ StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable In Stock £16.83
BTLZ StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable In Stock £17.06
BTLZ StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz In Stock £31.40
BTLZ StarTech.com USB C to DP Adapter - 8K/4K In Stock £14.75
BTLZ StarTech.com USB C to HDMI Adapter 4K 60Hz In Stock £12.26
Stock Status: While stocks last
Stock Status: Clearance
