StarTech.com USB C to HDMI Adapter 4K 60Hz
Quicklinx: GKNNWS00 Mfr#: USBC-HDMI-CDP2HD4K60
Length: 13cm
More than 50 In Stock
£12.49 ex VAT
£14.98 inc VAT
This USB-C to HDMI adapter lets you connect your USB Type-C laptop to an HDMI display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video. With brighter colors and greater contrast, the adapter is ideal for: • Creating eye-catching visuals for photography, videography, cinematography • Displaying crisp digital signage walls • Delivering enriched presentations.
  • True 4K at 60Hz and HDR
    The USB-C video adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 X 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI at their supported maximum resolutions. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
  • Ideal for Travel
    This lightweight 4K adapter is highly portable, with a small-footprint design. It's the perfect accessory for your USB-C laptop or MacBook, fitting easily into your carrying case.
  • Hassle-Free Setup
    To ensure easy operation and installation, this unique USB-C to HDMI adapter includes a reversible USB-C connector so you will always plug it into your laptop correctly on the first try. USBC-HDMI-CDP2HD4K60 is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes:
Startech USB C to HDMI Adapter, 4K 60Hz UHD Video, HDR10, USB-C to HDMI 2.0b Adapter Dongle, USB Type-C DP Alt Mode to HDMI Monitor/Display/Projector, USB C to HDMI Converter, M/F - Thunderbolt 3 Compatible - adapter - HDMI / USB - 13 cm
Cable
Adapter - HDMI / USB
Max Output Resolution
3840 x 2160 - 60 Hz
Cable Length
13 cm
Space grey
Connector
USB-C - male (input)
Connector (Second End)
HDMI - female (output)
Thunderbolt 3
Active adapter, 4K60Hz (3840 x 2160) support
3-year warranty
Cable Type
Adapter active, 4K60Hz (3840 x 2160) support
Interface Supported
HDMI / USB
Jacket Material
Plastic
Thunderbolt 3
Cable Length
13 cm
HDR 10 support, DisplayPort Alternate Mode support, 7.1 PCM audio channel support, ANX7517 chipset
Space grey
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Connector
24 pin USB-C - male (input)
19 pin HDMI Type A - female (output)
FCC, RoHS, WEEE, REACH, RCM
2.2 cm
1.05 cm
16 g
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Height
1.5 cm
Shipping Weight
22 g
Limited warranty - 3 years
GKNN StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
GKNN StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
GKNN StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.46
GKNN StarTech.com 5m 15ft Premium 4K HDMI Cable In Stock £24.69
GKNN StarTech.com 7m 23ft Premium 4K HDMI Cable In Stock £36.43
GKNN StarTech.com 0.5m Premium 4K HDMI Cable In Stock £9.95
Length: 13cm
