Connect your MacBook, Chromebook or laptop with USB-C to an HDMI display or projector. This USB-C to HDMI adapter lets you output HDMI video and audio from a USB Type-C device such as a MacBook or Chromebook laptop. This adapter works with USB-C devices that pass a DisplayPort video signal. It's also compatible with Thunderbolt 3 ports.
This USB type-C video adapter is highly portable with a small footprint and lightweight design. The adapter is the perfect accessory for your MacBook or Chromebook, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving you the hassle and embarrassment of fiddling with your device when you're trying to deliver a presentation.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. The adapter lets you harness the video capabilities built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
The CDP2HDW features a white housing that looks great with your MacBook.
Note: Your USB-C equipped device must support video to work with this adapter.
- StarTech.com USB C to HDMI Adapter - 4K 30Hz - USB 3.1 Type-C to HDMI Adapter - USB-C to HDMI Dongle - Monitor Adapter - White (CDP2HDW) - external video adapter - white
- External video adapter
- Bus Type
- USB-C
- Graphics Engine
- - up to
- Max Resolution
- 3840 x 2160
- Interfaces Details
- HDMI
- Enclosure Colour
- White
- 3-year warranty
- Designed For
- P/N: TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
- Bus Type
- USB-C
- Max Resolution
- 3840 x 2160
- HDMI
- USB powered
Video Input
- USB powered
- FCC, RoHS
- Enclosure Colour
- White
- Limited warranty - 3 years
- Designed For
StarTech.com USB-C to HDMI Adapter | In Stock | £15.52 |
StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz | In Stock | £6.73 |
StarTech.com 6ft USB-C to DisplayPort Cable | In Stock | £18.05 |
StarTech.com 2m USB-C to DVI Cable | In Stock | £23.46 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £27.98 |
StarTech.com USB-C to HDMI Adapter - 4K60Hz | In Stock | £16.01 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £22.59 |
StarTech.com USB-C to HDMI Presentation | In Stock | £14.13 |
StarTech.com USB-C to DisplayPort Adapter | In Stock | £20.19 |
StarTech.com 6 ft USB C to DP Cable - White | In Stock | £9.11 |
StarTech.com 3m USB C to DisplayPort Cable - White | In Stock | £20.18 |
StarTech.com 3m USB C to DisplayPort Cable - Black | In Stock | £26.32 |
StarTech.com 1.8m 6 ft USB C to mDP Cable | In Stock | £10.03 |
StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m | In Stock | £20.26 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.00 |
StarTech.com 5.9 ft (1.8 m) - USB-C to DisplayPort Adapter Cable | In Stock | £17.71 |
StarTech.com 3.3 ft. (1 m) - USB-C to DisplayPort Adapter Cable - 8K | In Stock | £23.05 |
StarTech.com 3.3 ft. (1 m)?USB C to DisplayPort 1.4 Cable? | In Stock | £19.42 |
StarTech.com 6.6?ft.?(2 m)?USB C to DisplayPort 1.4 Cable | In Stock | £11.25 |
StarTech.com 3.3 ft. (1 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.68 |
StarTech.com 6.6 ft. (2 m) USB C to DisplayPort 1.2 Cable | In Stock | £16.65 |
StarTech.com USB C to DisplayPort Adapter - Power Delivery - 8K 30Hz | In Stock | £16.65 |
StarTech.com USB C to DP Adapter - 8K/4K | In Stock | £13.33 |
StarTech.com USB C to HDMI Adapter 4K 60Hz | In Stock | £12.28 |
StarTech.com 6.6ft USB C to DP 1.2 Cable | In Stock | £31.29 |
