Connect to a Gigabit network through the USB Type-C port on your computer. Now, you can easily connect to a Gigabit network through the USB -C or Thunderbolt 3 port on your laptop or desktop computer. This Gigabit Ethernet (GbE) network adapter provides a reliable network connection without even having to install drivers. It's ready to go - with native driver support to ensure a quick setup.
The USB Type-C network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.1 Gen 1 (5 Gbps). You can access very large files over the network at Gigabit speeds.
Get up and running quickly. Simply plug the adapter into the USB-C port on your laptop and connect to your network. The network adapter chipset provides native driver support in Chrome OS, Mac OS 10.10, Windows 8.1.
The USB Type-C connector is smaller and easier to use than previous USB connectors. It's a reversible plug so you can connect to your devices with either side facing up. You can insert the cable the right way every time - without frustration or the risk of port damage.
Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. It's powered directly from the USB port making it easy to connect when you're on the go.
Powerful Gigabit Network Connections
The USB-C to LAN adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.1 Gen 1 (5Gbps). You can access very large files over the network at 10/100/1000Mbps network speeds with checksum offload (IPv4, IPv6, TCP, UDP) and large-send offload support. -
Uses USB Type-C and Thunderbolt 3
Instantly delivers Gigabit speeds using the USB-C or Thunderbolt 3 port on your device without requiring an internal Ethernet card in your device. -
Native Driver Support
Simply plug the network adapter into the USB-C port on your laptop and connect to your network. The adapter's Realtek RTL8153 chipset provides native driver support in Chrome OS , macOS and Windows . -
Compact and Lightweight Design
This portable USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory for those who require more portability. It's powered directly from the USB port making it easy to connect when you're on the go. Our USB network adapters make it easy to add a wired network connection to your laptop, desktop or tablet. If your device has a USB port available, then our compact USB network adapters can help you connect. This USB Type-C to Ethernet adapter is backed by a 2-year warranty and free lifetime North American based Technical Support.
- StarTech.com USB C to Gigabit Ethernet Adapter - Black - USB 3.1 to RJ45 LAN Network Adapter - USB Type C to Ethernet (US1GC30B) - network adapter - USB-C - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB-C
- Ports
- Gigabit Ethernet
- 2.5 cm 1.5 cm
- Length
- 21 cm
- 30 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Processor
- Realtek Semiconductor RTL8153
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3az, USB 3.1
- Black
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Linux Kernel 2.6.25 - 4.11.x LTS versions, Google Chrome OS
- 2-year warranty
- Designed For
- P/N: HB30C3A1CFB, HB30C3A1CFS, TB33A1C
- Network adapter
- Form Factor
- External
- USB-C
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Full duplex capability, WOL, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, plastic housing, Energy Efficient Ethernet, VLAN Tagging (not supported in MacOS)
Processor / Memory
- Processor
- 1 x 1000Base-T - RJ-45 - female
- FCC, RoHS
- Black
- OS Required
- 2.5 cm
- 1.5 cm
- Length
- 21 cm
- 30 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
- 5 - 90%
- Designed For
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter | In Stock | £23.76 |
StarTech.com USB-C to Gigabit Adapter | In Stock | £24.10 |
StarTech.com USB-C to Gigabit Adapter | In Stock | £24.60 |
StarTech.com USB-C to Gigabit Adapter | In Stock | £37.94 |
StarTech.com USB-C to GbE Adapter - Silver | In Stock | £28.29 |
StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop | In Stock | £32.45 |
StarTech.com USB-C to Dual GbE Adapter | In Stock | £57.13 |
StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White | In Stock | £25.21 |
StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 | In Stock | £51.07 |
StarTech.com USB-C Ethernet Adapter with Extra USB Port - USB 3.1 Type-C | In Stock | £36.60 |
