Add Gigabit Ethernet network connectivity to a Laptop or Desktop through a USB 3.0 port. The USB31000S USB 3.0 to Gigabit Ethernet Adapter adds a single RJ45 Ethernet port to a USB-enabled computer system, with support for Gigabit network connections at full bandwidth, unlike USB 2.0 adapters.
This compact USB 3.0 network adapter is backward compatible with older USB 2.0/1.x computer systems (speed limited by USB bus), making it the ideal portable replacement network adapter or laptop accessory. Plus, with support for features such as Jumbo Frames, VLAN tagging and Wake on LAN (WOL), the adapter offers a versatile Gigabit network solution for home and business users alike.
- Startech USB 3.0 to Gigabit Ethernet Adapter - 10/100/1000 NIC Network Adapter - USB 3.0 Laptop to RJ45 LAN (USB31000S) - network adapter - USB 3.0 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- Gigabit Ethernet
- 2.6 cm 1.55 cm
- Cable Length
- 67 cm
- 27 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Processor
- ASIX AX88179
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab
- Black
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Google Chrome OS 55 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
- 2-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Status Indicators
- Link/activity
- WOL, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, VLAN Tagging (not supported in MacOS)
Processor / Memory
- Processor
- ASIX AX88179
- 1 x 1000Base-T - RJ-45 - female
- FCC, RoHS
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 2.6 cm
- 1.55 cm
- Cable Length
- 67 cm
- 27 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £21.26 |
StarTech.com Mini PCI Express Gigabit Ethernet Network Adapter NIC Card | In Stock | £22.59 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter | In Stock | £23.36 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White | In Stock | £38.00 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White | In Stock | £20.71 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps | In Stock | £20.19 |
StarTech.com USB 3.0 to Dual Port Gigabit Ethernet Adapter NIC w/ USB Port | In Stock | £52.06 |
StarTech.com 1 Port PCI Express PCIe Gigabit NIC Server Adapter Network Card - Low Profile | In Stock | £19.43 |
StarTech.com USB-C to Gigabit Adapter | In Stock | £26.04 |
StarTech.com USB 3.0 Network Adapter-Silver | In Stock | £23.74 |
StarTech.com USB-C to Gigabit Adapter | In Stock | £36.31 |
StarTech.com USB-C to GbE Adapter - Silver | In Stock | £26.78 |
StarTech.com USB-C to Dual GbE Adapter | In Stock | £55.73 |
StarTech.com USB-C Ethernet Adapter with Extra USB Port - USB 3.1 Type-C | In Stock | £35.09 |
StarTech.com USB to Ethernet Adapter - 1Gb | In Stock | £19.33 |
