StarTech.com USB-C to DVI with USB PD
Quicklinx: D28HWS00 Mfr#: CDP2DVIUCPW
£26.16 ex VAT
£31.39 inc VAT
N/A. This USB-C to DVI adapter lets you connect a USB-C laptop, such as an Ultrabook or MacBook Pro, to a DVI display. The video adapter features USB Power Delivery, which enables you to power and charge your laptop while you're outputting video to a DVI display. To match the aesthetics of your device, this adapter is colored white.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the latest MacBook or Windows laptops. It's also compatible with Thunderbolt 3 ports.
Unlike some video adapters that use up one of your laptop's USB-C ports to output video, this video adapter offers an additional USB-C charge port that supports USB Power Delivery up to 60 watts. This means you can charge your laptop and output video using the same laptop port, by simply connecting the laptop's power adapter to the additional USB-C port on the adapter. It's the perfect solution for laptops that have only a limited number of USB-C ports.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your device, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so no matter how you plug it in, the adapter will always connect. This saves you the hassle and embarrassment of struggling with your device when you're trying to deliver a presentation or sharing information.
  • Charge your device at the same time
  • Take it with you
    This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your device, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this adapter perfect for BYOD applications at the office.
  • Connect quickly
StarTech.com USB C to DVI Adapter with Power Delivery, 1080p USB Type-C to DVI-D Single Link Video Display Converter with Charging, 60W PD Pass-Through, Thunderbolt 3 Compatible, White - USB-C Display Adapter (CDP2DVIUCPW) - external video adapter - Parade PS171 - white
External video adapter
Bus Type
USB-C
Graphics Engine
Parade PS171
Max Resolution
1920 x 1200
Interfaces Details
DVI-I
3.3 cm x 5 cm x 1.3 cm
Enclosure Colour
White
3-year warranty
Bus Type
USB-C
Graphics Engine
Parade PS171
Max Resolution
1920 x 1200 at 60 Hz
Interfaces Details
DVI-I
USB powered, Thunderbolt 3 compatible
Video Input
USB powered
FCC, RoHS, WEEE
3.3 cm
5 cm
1.3 cm
24 g
Enclosure Colour
White
Limited warranty - 3 years
45 °C
0 - 90% (non-condensing)
D28H StarTech.com USB-C to VGA Adapter In Stock £22.16
D28H StarTech.com USB-C to HDMI Adapter In Stock £15.94
D28H StarTech.com USB-C to HDMI Adapter In Stock £15.52
D28H StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.98
D28H StarTech.com USB-C to DisplayPort Adapter In Stock £22.59
D28H StarTech.com USB-C to DVI with USB PD In Stock £10.14
