Connect two independent displays to a single USB Type-C port. This MST hub lets you connect two HDMI monitors to your USB-C computer. MST works on any Windows device that supports DP Alt Mode over USB Type-C, such as models of Dell Precision and Dell XPS laptops and ASUS ROG GL752. The MST hub also works with Thunderbolt 3 ports to provide Thunderbolt 3 to dual HDMI conversion.
The USB-C HDMI hub is powered by the USB-C port, so you don't require an additional power adapter. This adapter works with USB Type-C devices that pass a DisplayPort video signal.
The newest generations of laptops are more portable than ever. But, this could mean that you're left with fewer video outputs and confined to your laptop's integrated screen. This USB-C MST hub solves these problems by letting you connect two independent HDMI displays through a USB-C port on your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity - perfect for creating a hot-desk solution with a wireless keyboard and mouse peripheral set.
The hub also lets you mirror the same image onto multiple displays, for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and offers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, it's perfect for all high-resolution applications such as graphic design and CAD drawing.
Your USB-C equipped device must support video (DP Alt Mode) to work with this adapter.
MST shares 21.6Gbps across all attached displays. Higher resolutions can restrict the available bandwidth with the remaining ports.
Multi-tasking Made Easy
With devices becoming more portable than ever, you can be limited to fewer video outputs and confined to your small integrated screen. This multi-stream transport hub solves that problem by enabling you to connect two separate displays to your USB-C computer, making multi-tasking much easier. Using this USB-C to HDMI video splitter, you can mirror your display onto additional monitors or stream independent content to each display, which makes it the ideal accessory for travel or hot-desking. -
Astonishing Picture Quality
MST technology uses your existing video card to minimize the use of system resources, while delivering UHD 4K resolutions for two monitors or displays simultaneously. With support for HD 1080p and UHD 4K the USB-C hub is perfect for all high-resolution applications such as graphic design and CAD drawing. -
Hassle-Free Setup
Multi-stream transport offers an easy setup by natively working on any Windows device that supports DP Alt Mode over USB Type-C. This USB-C to HDMI hub is Thunderbolt 3 compatible, and offers plug-and-play installation with no drivers or software required. Additionally, this dual-monitor splitter is powered by the USB-C port, meaning no external power cords are necessary. MSTCDP122HD is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
- StarTech.com 2-Port Multi Monitor Adapter, USB-C to 2x HDMI Video Splitter, USB Type-C DP Alt Mode to HDMI MST Hub, Dual 4K 30Hz or 1080p 60Hz, Compatible with Thunderbolt 3, Windows Only - Multi Stream Transport (MSTCDP122HD) - adapter cable - HDMI / USB - 44 m
- Cable
- Adapter cable - HDMI / USB
- Max Output Resolution
- 3840 x 2160 - 30 Hz
- Length
- 44 m
- Black
- Connectors
- 24 pin USB-C - male (input)
- Connectors (Second End)
- 2 x HDMI - female (output)
- Displayport 1.2/Thunderbolt 3
- 4K30Hz (3840 x 2160) support, 2560 x 1600 (WQXGA) support 60Hz
- 3-year warranty
- Designed For
- P/N: TB33A1C
- Cable Type
- Adapter cable 4K30Hz (3840 x 2160) support, 2560 x 1600 (WQXGA) support 60Hz
- Interface Supported
- HDMI / USB
- Length
- 44 m
- DisplayPort Alternate Mode support, Multi Stream Transport (MST), 7.1 channel Surround Sound
- Black
Adapters & Converters
- 3840 x 2160
- Refresh Rate
- 30 Hz
- OS Required
- Windows 8 / 8.1 / 10
- Connectors
- 2 x 19 pin HDMI Type A - female (output)
- FCC, RoHS
- 5.8 cm
- 6.2 cm
- 1.3 cm
- Shipping Width
- 14.4 cm
- Shipping Depth
- 17.4 cm
- Shipping Height
- 3.2 cm
- Shipping Weight
- 143 g
- Limited warranty - 3 years
- Designed For
- P/N: TB33A1C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.52 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £10.03 |
StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.68 |
StarTech.com 1m Mini HDMI to DVI-D Cable - M/M | In Stock | £11.54 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £8.02 |
StarTech.com USB-C to VGA Adapter - White | In Stock | £22.46 |
StarTech.com USB-C to HDMI Adapter | In Stock | £18.89 |
StarTech.com USB-C to DisplayPort MST Hub - 2-Port | In Stock | £40.42 |
StarTech.com 2m USB-C to DVI Cable | In Stock | £24.22 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £31.13 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com USB-C to VGA - Power Delivery | In Stock | £10.58 |
StarTech.com USB-C to HDMI - Power Delivery | In Stock | £25.82 |
StarTech.com USB-C to 2x HDMI MST Splitter | In Stock | £34.16 |
StarTech.com USB-C to DP MST Hub - 3-Port | In Stock | £52.91 |
StarTech.com 3-Port USB C to HDMI MST Hub | In Stock | £46.68 |
StarTech.com 2m/6.6 ft Premium High Speed HDMI Cable with Ethernet | In Stock | £17.97 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £17.51 |
StarTech.com USB C Dual HDMI MST HUB 4K | In Stock | £34.29 |
StarTech.com 3-Port USB-C MST Hub, 4K 60Hz | In Stock | £47.21 |
StarTech.com 2-Port USB-C MST Hub, 4K 60Hz | In Stock | £48.16 |
StarTech.com USB-C Triple DP MST HUB 4K | In Stock | £55.58 |
