View your pictures or videos from your HDMI Mini-equipped camera or other mobile device up to 1m away from your DVI-D display. The HDCDVIMM1M 1m Mini HDMI to DVI-D Cable enables you to view your pictures and videos from your HDMI Mini-equipped camera or other mobile device (Tablet, laptop, etc.) on a DVI-D capable display or projector. As an option, in order to incorporate audio with your video presentations you can use the 3ft (1m) Slim 3.5mm Stereo Audio Cable (MU3MMS).
The HDCDVIMM1M is designed and constructed for maximum durability, to ensure dependable performance.
- StarTech.com 1m (3.3 ft) Mini HDMI to DVI Cable, DVI-D to HDMI Cable (1920x1200p), 19 Pin HDMI Mini (C) Male to DVI-D Male, Digital Monitor Cable Adapter M/M, Single Link, Black - Mini HDMI to DVI Adapter - adapter cable - HDMI / DVI - 1 m
- Cable
- Adapter cable - HDMI / DVI
- Technology
- Shielded
- American Wire Gauge (AWG)
- 30
- Length
- 1 m
- Black
- Connector
- DVI-D - male
- Connector (Second End)
- 19 pin mini HDMI Type C - male
- Moulded
- Limited lifetime warranty
- Designed For
- P/N: MSTCDP122HD
- Cable Type
- Adapter cable
- Interface Supported
- HDMI / DVI
- Technology
- Shielded
- 30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Gold
- Moulded
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- RoHS
- Limited warranty - lifetime
- Designed For
- P/N: MSTCDP122HD
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.28 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £9.78 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.59 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Female to DVI Male | In Stock | £9.80 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £10.14 |
StarTech.com 2m Mini HDMI to DVI-D Cable - M/M | In Stock | £13.29 |
StarTech.com 1m Mini HDMI to DVI-D Cable - M/M | In Stock | £11.34 |
