StarTech.com USB-C to 2x HDMI MST Splitter
Quicklinx: CT5JWS00 Mfr#: MSTCDP122HD
Hurry, only 1 left in stock!
£31.99 ex VAT
£38.38 inc VAT
Express delivery Delivered on Wednesday
Connect two independent displays to a single USB Type-C port. This MST hub lets you connect two HDMI monitors to your USB-C computer. MST works on any Windows device that supports DP Alt Mode over USB Type-C, such as models of Dell Precision and Dell XPS laptops and ASUS ROG GL752. The MST hub also works with Thunderbolt 3 ports to provide Thunderbolt 3 to dual HDMI conversion.
The USB-C HDMI hub is powered by the USB-C port, so you don't require an additional power adapter. This adapter works with USB Type-C devices that pass a DisplayPort video signal.
The newest generations of laptops are more portable than ever. But, this could mean that you're left with fewer video outputs and confined to your laptop's integrated screen. This USB-C MST hub solves these problems by letting you connect two independent HDMI displays through a USB-C port on your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity - perfect for creating a hot-desk solution with a wireless keyboard and mouse peripheral set.
The hub also lets you mirror the same image onto multiple displays, for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and offers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, it's perfect for all high-resolution applications such as graphic design and CAD drawing.
Your USB-C equipped device must support video (DP Alt Mode) to work with this adapter.
MST shares 21.6Gbps across all attached displays. Higher resolutions can restrict the available bandwidth with the remaining ports.
  • Multi-tasking Made Easy
    With devices becoming more portable than ever, you can be limited to fewer video outputs and confined to your small integrated screen. This multi-stream transport hub solves that problem by enabling you to connect two separate displays to your USB-C computer, making multi-tasking much easier. Using this USB-C to HDMI video splitter, you can mirror your display onto additional monitors or stream independent content to each display, which makes it the ideal accessory for travel or hot-desking.
  • Astonishing Picture Quality
    MST technology uses your existing video card to minimize the use of system resources, while delivering UHD 4K resolutions for two monitors or displays simultaneously. With support for HD 1080p and UHD 4K the USB-C hub is perfect for all high-resolution applications such as graphic design and CAD drawing.
  • Hassle-Free Setup
    Multi-stream transport offers an easy setup by natively working on any Windows device that supports DP Alt Mode over USB Type-C. This USB-C to HDMI hub is Thunderbolt 3 compatible, and offers plug-and-play installation with no drivers or software required. Additionally, this dual-monitor splitter is powered by the USB-C port, meaning no external power cords are necessary. MSTCDP122HD is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
StarTech.com 2-Port Multi Monitor Adapter, USB-C to 2x HDMI Video Splitter, USB Type-C DP Alt Mode to HDMI MST Hub, Dual 4K 30Hz or 1080p 60Hz, Compatible with Thunderbolt 3, Windows Only - Multi Stream Transport (MSTCDP122HD) - adapter cable - HDMI / USB - 44 m
Cable
Adapter cable - HDMI / USB
Max Output Resolution
3840 x 2160 - 30 Hz
Length
44 m
Connectors
24 pin USB-C - male (input)
Connectors (Second End)
2 x HDMI - female (output)
Displayport 1.2/Thunderbolt 3
4K30Hz (3840 x 2160) support, 2560 x 1600 (WQXGA) support 60Hz
3-year warranty
P/N: TB33A1C
Cable Type
Adapter cable 4K30Hz (3840 x 2160) support, 2560 x 1600 (WQXGA) support 60Hz
Interface Supported
HDMI / USB
Length
44 m
DisplayPort Alternate Mode support, Multi Stream Transport (MST), 7.1 channel Surround Sound
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Windows 8 / 8.1 / 10
Connectors
2 x 19 pin HDMI Type A - female (output)
FCC, RoHS
5.8 cm
6.2 cm
1.3 cm
Shipping Width
14.4 cm
Shipping Depth
17.4 cm
Shipping Height
3.2 cm
Shipping Weight
143 g
Limited warranty - 3 years
P/N: TB33A1C
CT5J StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
CT5J StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.54
CT5J StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £5.92
CT5J StarTech.com 1m Mini HDMI to DVI-D Cable - M/M In Stock £10.34
CT5J StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.03
CT5J StarTech.com USB-C to VGA Adapter - White In Stock £23.49
CT5J StarTech.com USB-C to HDMI Adapter In Stock £18.89
CT5J StarTech.com USB-C to DisplayPort MST Hub - 2-Port In Stock £38.47
CT5J StarTech.com 2m USB-C to DVI Cable In Stock £22.21
CT5J StarTech.com 2m USB-C to HDMI Cable In Stock £27.69
CT5J StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.34
CT5J StarTech.com USB-C to HDMI - Power Delivery In Stock £23.36
CT5J StarTech.com USB-C to 2x HDMI MST Splitter In Stock £31.99
CT5J StarTech.com 3-Port USB C to HDMI MST Hub In Stock £42.71
CT5J StarTech.com 2m/6.6 ft Premium High Speed HDMI Cable with Ethernet In Stock £15.94
CT5J StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.98
CT5J StarTech.com USB C Dual HDMI MST HUB 4K In Stock £33.93
CT5J StarTech.com 3-Port USB-C MST Hub, 4K 60Hz In Stock £45.58
CT5J StarTech.com 2-Port USB-C MST Hub, 4K 60Hz In Stock £46.21
