StarTech.com USB-C Multiport Adapter Docking Station
Quicklinx: DV1LWS00 Mfr#: DK30C2HAGPD
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black
More than 50 in stock
£95.18 ex VAT
£114.21 inc VAT
This USB-C multiport adapter turns your Windows laptop into a portable workstation. The dual HDMI adapter connects your USB-C laptop to two HDMI monitors, letting you power through work faster or make presentations with different views on two displays. It gives you two USB-A ports, a Gigabit Ethernet port, a DP Alt Mode Switch, and laptop charging.
Through 100W Power Delivery 3.0, the USB Type-C multiport adapter powers itself as well as your laptop and any attached peripherals, with up to 85W laptop charging when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you unplug the power adapter to switch power sources (USB-C power adapter to bus power).
The USB-C HDMI multiport adapter extends your laptop screen to dual HDMI displays. Using the DP Alt Mode switch, you can choose between higher display resolution or faster USB speed to meet your needs, for desktop or portable use. Choose between: dual 4K30 (or single 4K60) resolution with USB 2.0 speed, or dual 1080p (or single 4K30) resolution with USB 3.0 speed.
The USB-C display adapter gives you two USB-A ports (one USB 3.0/USB 2.0 port, and one USB 2.0) to connect your mouse, keyboard or other peripherals.
The GbE port ensures reliable wired network access. A 1 m USB-C cable is included for greater flexibility.
Note: To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
  • Laptop charging with PD 3.0
    Through 100 W?Power Delivery?3.0, ?the?USB?Type-C multiport adapter?powers itself as well as your laptop and any attached peripherals, with up to 85W laptop charging when connected to a USB-C power adapter. ?PD?3.0 features Fast Role Swap to prevent USB data disruption when?you?unplug?the power adapter to?switch?power sources (USB-C?power adapter to?bus power).
  • Connect to dual HDMI monitors?with flexible resolution options
    The USB-C HDMI multiport adapter extends your laptop screen to?dual HDMI displays. Using the DP Alt Mode switch, you can choose between higher display resolution or faster USB speed to meet your needs, for desktop or portable use. Choose between: dual 4K30 (or single 4K60) resolution with USB 2.0 speed, or dual 1080p (or single 4K30) resolution with USB 3.0 speed.
StarTech.com Dual Monitor USB C Docking Station - For Windows Laptops - HDMI Multiport Adapter (DK30C2HAGPD) - docking station - 2 x HDMI
Docking station
Docking Interface
USB-C
Video Interfaces
2 x HDMI
6 cm x 12 cm x 1.88 cm
200 g
Gigabit Ethernet
3-year warranty
P/N: ARMBARDUO, ARMBARDUOV, ARMDUAL, ARMDUAL30, ARMDUALV, ARMSLIMDUO
Docking station
6 cm
12 cm
1.88 cm
200 g
Enclosure Colour
Gigabit Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
1 x SuperSpeed USB 3.0 - 24 pin USB-C , 1 x USB-C with Power Delivery - 24 pin USB-C , 2 x display / video - HDMI output - 19 pin HDMI Type A , 1 x network - Ethernet 1000 - RJ-45 , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB - 4 pin USB Type A
1 x USB-C cable
USB powered, dual display support, 4K Ultra HD, 85W power delivery, auto MDIX support
FCC, RoHS, WEEE, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
Microsoft Windows 7 / 8 / 8.1 / 10
Limited warranty - 3 years
Shipping Weight
220 g
50 °C
StarTech.com USB-C Multiport Adapter Docking Station Bundle deal on StarTech.com USB-C Multiport Adapter Docking Station
£194.35
DV1L StarTech.com 3ft Micro USB Cable - A to Micro B In Stock £3.84
DV1L StarTech.com USB-C Multifunction Adapter 4K In Stock £48.40
DV1L StarTech.com USB-C Multifunction Adapter In Stock £61.61
DV1L StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £35.39
DV1L StarTech.com USB-C to VGA Adapter with PD In Stock £31.26
DV1L StarTech.com USB-C Multiport Adapter - DVI In Stock £49.60
DV1L StarTech.com USB-C Multiport Adapter - HDMI In Stock £49.39
Device Type: Laptop
Colour: Black
Price Range Ex VAT: 50 - 100
