This USB 3.2/3.1 Gen1 5Gbps USB-C cable lets you connect your USB Type-C devices for syncing, charging and powering your devices. The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
Power your USB-C devices
With up to 5A (100W) of power delivery, you can power a USB-C laptop, such as your Apple MacBook or Microsoft Surface Book. Simply connect the cable to your USB-C laptop and to a USB-C wall charger. You can use this USB Type-C cable to power your USB-C hard drive from the USB-C port on your laptop. -
Deliver 8K video with DisplayPort 1.4 Alt Mode
The cable supports 8K 30Hz video with DisplayPort 1.4 and is backward compatible to connect your docking station or laptop to a monitor that supports 4K or 1080p resolutions. -
Charge your mobile devices
When used with devices that support PD 3.0, this cable charges up to 20V and 5A for a maximum of 100W. It can decrease your charge time and make sure your mobile devices are ready, whenever you need them.
- StarTech.com 6ft (2m) USB C Cable 5Gbps, High Quality USB-C Cable, USB 3.1/3.2 Gen 1 Type-C Cable, 100W (5A) Power Delivery Charging, DP Alt Mode, USB C to C Cord, Charge & Sync - Thunderbolt 3 Compatible (USB315CCV2M) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 2 m
- USB-C cable
- Technology
- Shielded
- 8K30Hz support, USB Power Delivery (5A, 100W), Power Delivery 3.0 (PD 3.0) technology, 5 Gbps data rate
- Length
- 2 m
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB 3.1 Gen 2 / Thunderbolt 3 / DisplayPort 1.4
- Grey, black
- 2-year warranty
- Designed For
- P/N: DK30C2DAGPD, DK30C2HAGPD
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 32
- Plated Connector
- Nickel
- Length
- 2 m
- Grey, black
- 100 g
- Connector
- USB 3.1 Gen 2 / Thunderbolt 3 / DisplayPort 1.4, RoHS, WEEE
- 2-year warranty
- Designed For
StarTech.com Rugged Right Angle USB-C Cable 1m | In Stock | £27.51 |
StarTech.com 3m Active USB-C Cable, USB 3.2 | In Stock | £46.67 |
