StarTech.com USB-C Multiport Adapter - Gen 2 Hub 10Gbps - HDMI and VGA
Quicklinx: FX32WS00 Mfr#: DKT31CHVL
Device Type: Laptop, Tablet
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Grey
More than 50 In Stock
£47.37 ex VAT
£56.84 inc VAT
A USB 3.1 Gen 2 Type-C hub adapter, ideal for travel, features everything from the essential HDMI or VGA video outputs to faster USB-C & USB-A peripheral ports.?All through a single host cable, providing more flexibility for harder to reach laptop and tablet connections.
  • Two Video Output Options with HDMI & VGA
    This?USB-C multiport adapter?features both an 4K 30Hz HDMI and VGA port providing you with two?single?video output options for your?boardroom presentations or your?workstation setup including support for an ultra-wide monitor.
  • Designed for Portability & Ease of Use
    The USB-C travel dock is bus-powered through an attached extended length 29cm host cable, accommodating a wide variety of setups, so there's no need to carry around a separate bulky power adapter. Installation is fast and simple, with native support in most operating systems and at only 1.94 ounces (55 g) and taking up less space than your smartphone, this dock easily fits in your laptop bag or briefcase.
  • Simplistic Port Configuration
    In addition to the video outputs, the portable USB-C dock gives you one 10G USB-C port and USB-A port to connect your latest and legacy USB devices.?The adapter also integrates a Gigabit Ethernet port to access a wired network.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB-C Multiport Adapter - USB 3.1 Gen 2 Type-C Mini Dock - USB-C to 4K HDMI or 1080p VGA Video - 10Gbps USB-A USB-C, GbE - Portable Travel Laptop Dock - Works w/Thunderbolt 3 (DKT31CHVL) - docking station - USB-C - VGA, HDMI - 1GbE - TAA Compliant
Docking station
Docking Interface
USB-C
Video Interfaces
VGA, HDMI
6.1 cm x 6 cm x 1.7 cm
55 g
Gigabit Ethernet
TAA Compliant
3-year warranty
Docking station
6.1 cm
6 cm
1.7 cm
55 g
Enclosure Colour
Video
Max Resolution Details
3840 x 2160 - 30 Hz (HDMI only) , 2048 x 1280 - 30 Hz (VGA only)
1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 1000Base-T - RJ-45 , 1 x USB-C / Thunderbolt 3 with Power Delivery - 24 pin USB-C
1 x USB-C cable - integrated - 25 cm
Bus powered, auto MDIX support
FCC, RoHS, WEEE, REACH, RCM, UASP (USB Attached SCSI Protocol)
TAA Compliant
Android, Google Chrome OS, Apple macOS 10.12 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years , Technical support - lifetime
60 °C
FX32 StarTech.com USB C Multiport Adapter - 4K HDMI/PD/USB/GbE- Mini Dock In Stock £58.01
FX32 StarTech.com USB C Multiport Adapter In Stock £64.31
FX32 StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.98
Device Type: Laptop
Device Type: Tablet
Colour: Grey
