StarTech.com USB C Multiport Adapter
Quicklinx: GFGWWS00 Mfr#: DKT31CMDPHPD
Device Type: Laptop, Desktop Computer, Tablet
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Grey
£64.31 ex VAT
£77.17 inc VAT
USB-C Multiport Adapter - HDMI & Mini DisplayPort Video - 100W PD Pass-Through - 4-Port USB Hub.
  • Maximum Resolution
    The portable docking station connects your laptop to a 4K 60Hz HDMI or mini DisplayPort monitor (4096 x 2160p) to create a powerful workstation. Can be used with an mDp to DP video adapter to connect your DP monitor and can also connect to an ultrawide monitor.
  • Connect Your Devices
    The USB-C to USB 3.1 Gen 2 hub gives you one USB-C port and three USB-A ports to connect your legacy USB devices.
  • Charge Your Laptop and Peripheral
    With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). The DKT31CMDPHPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
StarTech.com USB C Multiport Adapter, USB-C to HDMI or Mini DisplayPort 4K 60Hz, 100W Power Delivery Pass-Through, 4-Port 10Gbps USB Hub, USB Type-C Mini Dock, 12"/30cm Long Attached Cable - Works w/ Thunderbolt 3 (DKT31CMDPHPD) - docking station - USB-C / Thunderbolt 3 - HDMI, Mini DP
Docking station
Docking Interface
Video Interfaces
HDMI, Mini DP
84.3 g
3-year warranty
Docking station
84.3 g
Video
Max Resolution Details
4K - 60 Hz (DisplayPort 1.4 only) , 4K - 30 Hz (DisplayPort 1.2 only)
1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - Mini DisplayPort - Mini DisplayPort , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C 3.2 Gen 2 with Power Delivery (100 W) (power only) - 24 pin USB-C , 1 x USB 3.2 Gen 2 with Battery Charging 1.2 - 9 pin USB Type A , 2 x USB 3.2 Gen 2 - 9 pin USB Type A
1 x USB-C cable - integrated - 30 cm
100W power delivery, DisplayPort Alt Mode
DisplayPort 1.4, USB Power Delivery 3.0, FCC, RoHS
Windows 8.1 / 10 / 11, Apple macOS 10.13 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Google Chrome OS, Ubuntu 18.04, Ubuntu 20.04, Apple iPadOS, Android
Limited warranty - 3 years
Shipping Width
14 cm
Shipping Depth
17 cm
Shipping Height
3 cm
Shipping Weight
153 g
GFGW StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter In Stock £9.27
GFGW StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £15.43
GFGW StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.36
GFGW StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £26.27
GFGW StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.98
Device Type: Laptop
Device Type: Desktop Computer
Device Type: Tablet
Colour: Grey
