StarTech.com USB-C Multiport Adapter - DVI
Quicklinx: CX8TWS00 Mfr#: DKT30CDVPD
19 in stock
£48.15 ex VAT
£57.78 inc VAT
Charge your laptop through USB-C and create a workstation wherever you go, with DVI video output, Gigabit Ethernet and a USB-A port. Expand the connectivity of your USB-C enabled laptop. This sleek USB-C multiport adapter lets you create a powerful workstation virtually anywhere, providing DVI video output, one USB 3.0 Type-A port, and a Gigabit Ethernet port.
You can also power both the multiport adapter and your laptop simultaneously, with support for USB Power Delivery 2.0. It's the ideal accessory for your Dell XPS, MacBook Pro or other USB Type-C equipped laptop, and it's also Thunderbolt 3 port compatible.
The multiport adapter expands the connectivity of your port-limited laptop, using the built-in USB-C cable to connect to multiple devices simultaneously. When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a dual-monitor workstation when you need it. Connect to a DVI display in an office workspace or your home office with ease.
The Gigabit Ethernet port ensures reliable wired network access, plus with an additional USB 3.0 Type-A port, you can connect an existing peripheral device, like your mouse or flash drive.
The Gigabit Ethernet port ensures reliable wired network access, ideal for areas with limited Wi-Fi availability.
This compact multiport adapter is USB-powered, so there's no need to carry a separate power adapter with you. Ideal for mobile use from office to home, or for travel, the multiport adapter features a USB-C port that supports USB Power Delivery 2.0 so you can power and charge your laptop as you work. The adapter features a built-in USB-C cable and gives you network connectivity plus a USB Type-A connection for optimum versatility as you travel.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
StarTech.com USB-C Multiport Adapter - Power Delivery - DVI - GbE - USB 3.0 - external video adapter - white
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
Network (RJ-45) , DVI-I (female connector) , USB 3.0 (female connector) , USB-C (power only) (female connector) , USB-C (male connector)
4.1 cm x 9.7 cm x 1.7 cm
Enclosure Colour
White
3-year warranty
Bus Type
USB-C
Max Resolution
1920 x 1200
HD/4k Ready
Video Input
USB powered
Google Chrome OS, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS 10.12 Sierra
1 x USB-C cable
FCC, RoHS, WEEE
4.1 cm
9.7 cm
1.7 cm
48.7 g
Enclosure Colour
White
Limited warranty - 3 years
45 °C
0 - 85% (non-condensing)
StarTech.com USB-C Multiport Adapter - DVI Bundle deal on StarTech.com USB-C Multiport Adapter - DVI
£147.32
CX8T StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI GbE In Stock £48.25
CX8T StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £67.48
CX8T StarTech.com USB-C Multifunction Adapter 4K In Stock £54.49
CX8T StarTech.com USB-C Multifunction Adapter In Stock £60.65
CX8T StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £34.49
CX8T StarTech.com USB-C to VGA Adapter with PD In Stock £30.47
CX8T StarTech.com USB-C Multiport Adapter - DVI In Stock £48.15
Price Range Ex VAT: 0 - 50
