Charge your laptop through USB-C and create a workstation wherever you go, with DVI video output, Gigabit Ethernet and a USB-A port. Expand the connectivity of your USB-C enabled laptop. This sleek USB-C multiport adapter lets you create a powerful workstation virtually anywhere, providing DVI video output, one USB 3.0 Type-A port, and a Gigabit Ethernet port.
You can also power both the multiport adapter and your laptop simultaneously, with support for USB Power Delivery 2.0. It's the ideal accessory for your Dell XPS, MacBook Pro or other USB Type-C equipped laptop, and it's also Thunderbolt 3 port compatible.
The multiport adapter expands the connectivity of your port-limited laptop, using the built-in USB-C cable to connect to multiple devices simultaneously. When coupled with your laptop display, this versatile USB-C multiport adapter makes it easy to create a dual-monitor workstation when you need it. Connect to a DVI display in an office workspace or your home office with ease.
The Gigabit Ethernet port ensures reliable wired network access, plus with an additional USB 3.0 Type-A port, you can connect an existing peripheral device, like your mouse or flash drive.
The Gigabit Ethernet port ensures reliable wired network access, ideal for areas with limited Wi-Fi availability.
This compact multiport adapter is USB-powered, so there's no need to carry a separate power adapter with you. Ideal for mobile use from office to home, or for travel, the multiport adapter features a USB-C port that supports USB Power Delivery 2.0 so you can power and charge your laptop as you work. The adapter features a built-in USB-C cable and gives you network connectivity plus a USB Type-A connection for optimum versatility as you travel.
To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery and DP Alt Mode.
- StarTech.com USB C Multiport Adapter to DVI-D (Digital) Video - 60W PD Passthrough/GbE/USB-A - Portable USB Type-C/Thunderbolt 3 Mini Dock - external video adapter - white
- External video adapter
- Bus Type
- USB-C
- Max Resolution
- 1920 x 1200
- Network (RJ-45) , DVI-I (female connector) , USB 3.0 (female connector) , USB-C (power only) (female connector) , USB-C (male connector)
- 4.1 cm x 9.7 cm x 1.7 cm
- Enclosure Colour
- White
- 3-year warranty
- Bus Type
- USB-C
- Max Resolution
- 1920 x 1200
- HD/4k Ready
Video Input
- USB powered
- OS Required
- Google Chrome OS, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS Sierra 10.12
- Cables Included
- 1 x USB-C cable
- FCC, RoHS, WEEE
- 4.1 cm
- 9.7 cm
- 1.7 cm
- 48.7 g
- Enclosure Colour
- White
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 0 - 85% (non-condensing)
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI GbE | In Stock | £48.85 |
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 | In Stock | £68.32 |
StarTech.com USB-C Multifunction Adapter 4K | In Stock | £47.58 |
StarTech.com USB-C Multifunction Adapter | In Stock | £61.41 |
StarTech.com USB-C to 4K HDMI Adapter with Power Delivery | In Stock | £34.93 |
StarTech.com USB-C to VGA Adapter with PD | In Stock | £30.85 |
StarTech.com USB-C Multiport Adapter - DVI | In Stock | £48.76 |
