This USB Type-C Headphone Splitter enables two 3.5mm audio connections. The 3.5mm ports accept 4-pole 3.5mm TRRS connectors and support simultaneous stereo audio output and headset/microphone input. The adapter also features an integrated 2.75in (7cm) USB-C cable.
Headset Mic/Stereo Audio Control on the 3.5mm Ports
Connect two headsets to the same USB-C port. Microphone input is supported across both headsets, offering a convenient solution for team training and conferencing calls. The adapter supports dual CTIA or dual OMTP headset types allowing universal compatibility. -
Lossless Audio with High-Impedance Headphones
The USB-C headset dongle features built-in 24-bit Digital to Analog Converter (DAC). The DAC supports a sampling rate of up to 192kHz for uncompromising quality and performance. -
Compact USB-C Audio Adapter
The USB-C to dual-audio adapter is small and lightweight, perfect for professionals who are frequently on the go. It is the ideal solution for adding two 3.5mm audio jacks to a USB-C device. This product is backed for 2 years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com USB-C Headphone Splitter, USB Type C Dual Headset Adapter w/Microphone Input, USB C to 3.5mm Adapter/Earphone Dongle, USB C to Audio Jack/Aux Output - Mic and Headset Controls, Built-in 24-bit DAC (USBC-AUDIO-SPLITTER) - audio splitter - 7 cm
- Cable
- Audio splitter
- Length
- 7 cm
- Black, space grey
- Connector
- 24 pin USB-C - male - straight
- Connector (Second End)
- 2 x mini jack - female - straight
- USB / USB 2.0
- Outer diameter 3.2 mm, built-in digital to analogue converter (DAC), strain relief
- 2-year warranty
- Cable Type
- Audio splitter
- Jacket Material
- Thermoplastic elastomer (TPE)
- USB / USB 2.0
- Length
- 7 cm
- Plated Connector
- Aluminium
- Black, space grey
- Connector
- 2 x mini-phone 3.5 mm - female - straight
- RoHS, FCC, WEEE
- Shipping Width
- 12.5 cm
- Shipping Depth
- 9 cm
- Shipping Height
- 0.82 cm
- Shipping Weight
- 20 g
- Limited warranty - 2 years , Technical support - lifetime
