StarTech.com USB C Audio & Charge Adapter - USB-C Audio Adapter w/Audio
Quicklinx: GB6BWS00 Mfr#: CDP2CAPDM
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Silver
£20.56 ex VAT
£24.67 inc VAT
USB Type-C Headphone and Charger Adapter Audio & Charge 60W PD. This USB C audio adapter with 60W power delivery features a USB Type-C audio port for your headset, audio out or data transfer, while allowing you to charge your laptop, tablet, or smartphone at the same time.
Listen & Charge Simultaneously
Make calls or listen to music with this USB C audio and charging adapter. The 2 in 1 headphone adapter with charge port allows you to use your USB-C headsets, speakers, or transfer data (USB 2.0 speeds) while simultaneously charging your device through Power Delivery pass through with Type C power adapter connected.
Sleek and Portable Design
The USB C audio adapter features a cable-less, dongle design with a convenient side-port layout to reduce cable clutter, making it perfect for professionals at their workstation or on-the-go. Constructed of high-quality materials, the portable adapter provides a reliable and affordable audio and charge solution for your USB Type-C devices.
Wide Compatibility
This USB C headset adapter is universally compatible enabling you to use your wired headphones with your USB Type-C or Thunderbolt 3 device, including the MacBook Pro, iPad Pro, Samsung Galaxy and Note.
CDP2CAPDM is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
  • Listen & Charge Simultaneously
  • Sleek and Portable Design
  • Wide Compatibility
    This USB C headset adapter is universally compatible enabling you to use your wired headphones with your USB Type-C or Thunderbolt 3 device, including the MacBook Pro, iPad Pro, Samsung Galaxy and Note. CDP2CAPDM is backed by a StarTech.com 3-year warranty, and free lifetime technical support.
StarTech.com USB C Audio & Charge Adapter, USB-C Audio Adapter with USB-C Audio Headphone/Headset Port and 60W USB Type-C Power Delivery Pass-through Charger, For USB-C Phone/Tablet/Laptop - USB-C Audio/Charging (CDP2CAPDM) - docking station - USB-C
Docking station
Docking Interface
USB-C
2.25 cm x 4.99 cm x 0.9 cm
8 g
Silver
3-year warranty
Docking station
2.25 cm
4.99 cm
0.9 cm
8 g
Enclosure Colour
Silver
USB-C with Power Delivery (60 W) - 24 pin USB-C , Audio - USB 2.0 - 24 pin USB-C
60W power delivery
FCC, RoHS, WEEE
Android, Apple macOS 10.13 - 10.15, Apple macOS 11.0, Windows 10 / 11 or later, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Width
9 cm
Shipping Depth
12.5 cm
Shipping Weight
9 g
45 °C
GB6B StarTech.com USB C Audio & Charge Adapter - 3.5mm Headphone Jack/ 60W USB In Stock £18.73
GB6B StarTech.com USB-C Headphone Splitter In Stock £19.68
GB6B StarTech.com USB-C Audio Adapter to 3.5mm In Stock £11.78
Device Type: Laptop
Colour: Silver
