StarTech.com USB-C Dual-4K Monitor Docking Station for Laptops
Quicklinx: DNR2WS00 Mfr#: DK30CHDPPDUE
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Silver, Black
£119.01 ex VAT
£142.81 inc VAT
Add dual monitors (4K HDMI & 4K DP), an SD card reader, multiple USB ports, GbE, and audio to your laptop, plus power and charge your laptop. This dual-monitor USB-C dock transforms your MacBook or Windows laptop into a dual Ultra HD 4K workstation, with support for 4K DisplayPort and HDMI monitors. It gives you all the connections to create a fully capable workstation, including an SD card reader slot.
The USB-C docking station features USB Power Delivery 2.0 (60W), to power and charge your laptop as you work. It's the perfect companion for your MacBook Pro or other Thunderbolt 3 equipped laptop.
The USB-C dock expands the display capabilities of your laptop across two Ultra HD 4K monitors. It enables DisplayLink and USB-C DP Alt Mode to allow dual 4K video output to HDMI and DisplayPort 4K monitors. With the dual-4K dock, you can connect: 1x 4K DisplayPort display at 3840 x 2160 resolution @ 30Hz; 1x 4K HDMI display at 3840 x 2160 resolution @ 30Hz.
The dock provides direct access to your SD memory cards or microSD cards (with adapter). The SD card slot can also be used for additional storage and backup through macOS X Time Machine or Windows 10 File History.
The dock provides four USB 3.0 (Type-A) ports to connect your peripherals, including a USB 3.0 fast-charge and sync port, a Gigabit Ethernet port, and combined 3.5 mm audio and microphone port.
Compatible with Mac and Windows, this universal dock works with USB-C and Thunderbolt 3 enabled laptops.
  • Create a dual-4K video workstation
    The USB-C dock expands the display capabilities of your laptop across two Ultra HD 4K monitors. It enables DisplayLink and USB-C DP Alt Mode to allow dual 4K video output to HDMI and DisplayPort 4K monitors. With the dual-4K dock, you can connect: • 1x 4K DisplayPort display at 3840 x 2160 resolution @ 30Hz • 1x 4K HDMI display at 3840 x 2160 resolution @ 30Hz
  • SD card reader
  • Ample connections
  • Universal support
  • Connected Device Transparency with the StarTech.com MAC Address Changer Utility
    The DK30CHDPPDUE, includes a free Windows application that enables you to better manage your enterprise network security. When you connect to your network through the ethernet port of the dock, the computer's MAC address is typically not broadcast to the network, as your network only sees the MAC address of the docking station. However, the StarTech.com MAC Address Changer or Cloning software enables the USB-C dock to use MAC address spoofing of the connected Windows laptop rather than the MAC address of the dock itself. This ensures your network administrators have full visibility of each device on the network and can monitor and limit activity accordingly. To request access to our MAC Address Changer utility, please contact our Technical Support Department by phone, live chat , or e-mail . The DK30CHDPPDUE is backed by a StarTech.com 3-year warranty and free lifetime technical support.
StarTech.com USB C Dock, Dual Monitor HDMI & DisplayPort 4K 30Hz, USB Type-C Laptop Docking Station 60W Power Delivery (PD), SD, 4-port USB-A 3.0 Hub, GbE, Audio, Thunderbolt 3 Compatible - USB 3.1 Gen 1 Dock (DK30CHDPPDUE) - docking station - USB-C - HDMI, DP - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI, DP
8 cm x 22 cm x 2.5 cm
385 g
Black, silver
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 120/230 V 60 Watt Power Provided
3-year warranty
Docking station
8 cm
22 cm
2.5 cm
385 g
Enclosure Colour
Black, silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card
1 x USB-C - input - 24 pin USB-C , 4 x SuperSpeed USB 3.0 - output - 9 pin USB Type A , 1 x display / video - HDMI output - 19 pin HDMI Type A , 1 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x audio - output - mini-phone 3.5 mm 4-pole , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
Compatible Slots
1 x SD / MMC Memory Card
1 x USB-C cable - external
Dual monitor support, UASP transfer protocol, 1 USB 3.0 fast charging port, DisplayLink DL-5700 chipset, Genesys Logic GL3515 chipset, VLI VL813 chipset, Texas Instruments TPS65983 chipset
Power adapter
AC 120/230 V
Power Provided
60 Watt
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple MacOS X 10.9 - 10.12, Apple macOS 10.14 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Ubuntu 18.04, Ubuntu 20.04, Google Chrome OS 55 or later
Limited warranty - 3 years
Shipping Weight
1.4 kg
60 °C
DNR2 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.95
DNR2 StarTech.com 3.5mm 3 Pin Headset Splitter In Stock £3.62
DNR2 StarTech.com 2m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £9.57
DNR2 StarTech.com 3m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £15.35
DNR2 StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £11.54
DNR2 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
DNR2 StarTech.com 6 ft DP to HDMI cable - 4K In Stock £15.82
Device Type: Laptop
Colour: Silver
Colour: Black
