StarTech.com USB-C Dock - Triple 4K Monitor - 2x DP + HDMI - 5x USB 3.0 - 100W USB PD
Quicklinx: F2G8WS00 Mfr#: DK30CH2DEPUE
Device Type: Laptop, Macbook
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Black/Silver
20 In Stock
£102.18 ex VAT
£122.61 inc VAT
This triple-4K dock for Mac, Windows and Chrome USB-C laptops?helps you take productivity to a whole new level. With three 4K video connections, 100W Power Delivery, and 5x USB 3.0 ports, the USB-C dock is perfect for your MacBook, Dell XPS, Chromebook or other USB-C laptop requiring additional ports.
  • Enhance Productivity
    The 4K USB-C docking station lets you create a three-monitor Ultra HD workstation. Connect: • 2x 4K DisplayPort (DisplayLink) at 4096 x 2160 resolution @ 60Hz / 3840 x 2160 @ 60Hz and • 1x 4K HDMI (DP Alt Mode) at 4096 x 2160 resolution @ 24Hz / 3840 x 2160 @ 30Hz For high-resolution applications, you can connect the dock to a 5K display at 60Hz, using the two DisplayPort ports.
  • 100W Power Delivery
    Using a single cable, the USB-C dock will power and charge power-hungry laptops, with up to 100W Power Delivery, and power your peripherals with its 150W power adapter.
  • Powerful Connections
    This triple-monitor docking station lets you transform your laptop into a full-sized workstation. It gives you five USB 3.0 ports (1x USB Type-C and 4x USB Type-A incl. 1x Fast-Charge port), a Gigabit Ethernet port, headset jack, and separate 3.5 mm audio and microphone ports.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB-C Dock, 4K Triple Monitor USB Type-C Docking Station with Dual DisplayPort & HDMI, 100W Power Delivery + Charging, USB 3.0/3.1 Gen 1 Hub (1x USB-C + 4x USB-A) w/ Ethernet - 100W PD Laptop Dock (DK30CH2DEPUE) - docking station - USB-C - HDMI, DP - 1GbE - TAA Compliant
Docking station
Docking Interface
USB-C
Video Interfaces
HDMI, DP
27 cm x 8.2 cm x 3.4 cm
385 g
Black, silver
United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 120/230 V 100 Watt Power Provided
TAA Compliant
3-year warranty
Docking station
27 cm
8.2 cm
3.4 cm
385 g
Enclosure Colour
Black, silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB-C - 24 pin USB-C , 1 x display / video - HDMI - 19 pin HDMI Type A , 2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x headphones - mini-phone 3.5 mm 4-pole , 1 x microphone - mini-phone 3.5 mm , 1 x speakers - mini-phone 3.5 mm , 1 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A
1 x USB-C cable - external
Security lock slot (cable lock sold separately), full duplex support, 100W power delivery, auto MDIX support
Security Slot Type
Kensington security slot
FCC, RoHS, WEEE, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 2.0, DisplayPort 1.2, UASP (USB Attached SCSI Protocol)
TAA Compliant
Power adapter
AC 120/230 V
Power Provided
100 Watt
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple MacOS X 10.9 - 10.12, Apple macOS 10.14 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Ubuntu 18.04, Ubuntu 20.04, Google Chrome OS 55 or later
Limited warranty - 3 years
F2G8 StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.00
F2G8 StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.43
F2G8 StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.35
F2G8 StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 In Stock £22.81
F2G8 StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook In Stock £16.15
F2G8 StarTech.com 6 ft DP to HDMI cable - 4K In Stock £14.20
F2G8 StarTech.com 3ft DP to DVI Converter Cable In Stock £14.57
F2G8 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £7.60
F2G8 StarTech.com 6' DP to VGA Cable with Audio In Stock £8.90
F2G8 StarTech.com Triple-Video Laptop Dock In Stock £89.78
F2G8 StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £11.52
Device Type: Laptop
Device Type: Macbook
