Connect your DVI monitor to a DisplayPort equipped computer. The StarTech.com DP2DVI2 DVI/DisplayPort adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of single link DVI capability. DP2DVI2 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Reliable connection
Equipped with a latching DP connector, this adapter ensures that the connection remains secure, minimizing the risk of accidental disconnections during use. -
High-resolution support
Supports video resolutions up to 1920 x 1200, allowing for clear and detailed image quality, perfect for both business presentations and multimedia viewing. -
Versatile compatibility
Designed with a male 20 pin DisplayPort and a female 24 + 5 pin DVI connector, this adapter works seamlessly with a range of devices, providing flexibility in connectivity. -
Compact design
The lightweight and portable nature of this adapter makes it an ideal accessory for users on the go, enabling quick connections without hassle. -
Environmentally compliant
This adapter meets both FCC and RoHS standards, ensuring that it adheres to strict safety and environmental regulations for peace of mind.
- StarTech DisplayPort to DVI-D Adapter - 1920x1200 - Passive DVI Video Converter with Latching DP Connector (DP2DVI2) - DisplayPort adapter - 15.2 cm
- Cable Length
- 15.2 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- DVI-I - female
- FCC, RoHS
- Black
- 3-year warranty
- Designed For
- P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
- Cable Length
- 15.2 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 24+5 pin combined DVI - female
- FCC, RoHS
- 3-year warranty
- Designed For
- P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.74 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £21.80 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £22.37 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.22 |
StarTech.com 6 ft DisplayPort to DVI Cable - M/M | In Stock | £5.47 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £8.02 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £10.00 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £20.86 |
StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 | In Stock | £41.39 |
StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £12.06 |
StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black | In Stock | £18.85 |
StarTech.com 3ft DP to DVI Converter Cable | In Stock | £14.62 |
