This triple-4K dock for Mac, Windows and Chrome USB-C laptops?helps you take productivity to a whole new level. With three 4K video connections, 100W Power Delivery, and 5x USB 3.0 ports, the USB-C dock is perfect for your MacBook, Dell XPS, Chromebook or other USB-C laptop requiring additional ports.
Enhance Productivity
The 4K USB-C docking station lets you create a three-monitor Ultra HD workstation. Connect: • 2x 4K DisplayPort (DisplayLink) at 4096 x 2160 resolution @ 60Hz / 3840 x 2160 @ 60Hz and • 1x 4K HDMI (DP Alt Mode) at 4096 x 2160 resolution @ 24Hz / 3840 x 2160 @ 30Hz For high-resolution applications, you can connect the dock to a 5K display at 60Hz, using the two DisplayPort ports. -
100W Power Delivery
Using a single cable, the USB-C dock will power and charge power-hungry laptops, with up to 100W Power Delivery, and power your peripherals with its 150W power adapter. -
Powerful Connections
This triple-monitor docking station lets you transform your laptop into a full-sized workstation. It gives you five USB 3.0 ports (1x USB Type-C and 4x USB Type-A incl. 1x Fast-Charge port), a Gigabit Ethernet port, headset jack, and separate 3.5 mm audio and microphone ports. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com USB-C Dock, 4K Triple Monitor USB Type-C Docking Station with Dual DisplayPort & HDMI, 100W Power Delivery + Charging, USB 3.0/3.1 Gen 1 Hub (1x USB-C + 4x USB-A) w/ Ethernet - 100W PD Laptop Dock (DK30CH2DEPUE) - docking station - USB-C - HDMI, DP - 1GbE - TAA Compliant
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- HDMI, DP
- 27 cm x 8.2 cm x 3.4 cm
- 385 g
- Black, silver
- Localisation
- United Kingdom, Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 120/230 V 100 Watt Power Provided
- TAA Compliant
- 3-year warranty
- Product Type
- Docking station
- 27 cm
- 8.2 cm
- 3.4 cm
- 385 g
- Enclosure Colour
- Black, silver
- Localisation
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
- 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB-C - 24 pin USB-C , 1 x display / video - HDMI - 19 pin HDMI Type A , 2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x headphones - mini-phone 3.5 mm 4-pole , 1 x microphone - mini-phone 3.5 mm , 1 x speakers - mini-phone 3.5 mm , 1 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A
- Cables Included
- 1 x USB-C cable - external
- Security lock slot (cable lock sold separately), full duplex support, 100W power delivery, auto MDIX support
- Security Slot Type
- Kensington security slot
- FCC, RoHS, WEEE, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 2.0, DisplayPort 1.2, UASP (USB Attached SCSI Protocol)
- TAA Compliant
- Power Device
- Power adapter
- Voltage Required
- AC 120/230 V
- Power Provided
- 100 Watt
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple MacOS X 10.9 - 10.12, Apple macOS 10.14 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Ubuntu 18.04, Ubuntu 20.04, Google Chrome OS 55 or later
- Limited warranty - 3 years
- 0 °C
- 40 °C
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.00 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £14.14 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.35 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £22.25 |
StarTech.com HDMI to VGA Video Adapter Converter with Audio for Desktop PC / Laptop / Ultrabook | In Stock | £16.15 |
StarTech.com 6 ft DP to HDMI cable - 4K | In Stock | £13.97 |
StarTech.com 3ft DP to DVI Converter Cable | In Stock | £14.57 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.60 |
StarTech.com 6' DP to VGA Cable with Audio | In Stock | £8.90 |
StarTech.com Triple-Video Laptop Dock | In Stock | £89.78 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £11.52 |
