StarTech.com USB-C Audio Adapter to 3.5mm
Quicklinx: J4KNWS00 Mfr#: USBCAUDIO2
Hurry, only 3 left in stock!
£13.46 ex VAT
£16.15 inc VAT
Connect wired headphones or earphones to a USB Type-C-enabled device with this USB-C to 3.5mm audio adapter. The built-in 32-bit DAC supports stereo sound and microphone functionality via the TRRS jack for clear audio. It delivers excellent sound quality with audio ranges from 44.1 to 384kHz and 16, 24, and 32-bit sample rates, providing a 105dBA signal-to-noise ratio. The stereo ADC features a 94dB SNR for microphone input, with 48kHz and 16-bit sampling. Compatible with USB-C and Thunderbolt devices, including Windows, macOS, and Linux computers, as well as phones and tablets running iOS or Android, it supports wired headphones and headsets with in-line controls. The compact, sleek adapter measures 5 inches (127mm) and features a flexible and durable TPE jacket with a soft-touch finish. Perfect for use on the go or at a workstation for audio playback, recording, or calls.
  • Superior Sound Quality
    Experience excellent sound quality supporting audio ranges from 44.1 to 384kHz and 16, 24, and 32-bit sample rates, delivering a 105dBA signal-to-noise ratio for crisp and detailed output. The stereo ADC features a 94dB SNR for microphone input, with 48kHz and 16-bit sampling, all powered by the Realtek ALC4030U chipset.
  • Wide Compatibility
    This versatile aux audio adapter is universally compatible with USB-C and Thunderbolt devices, including Windows, macOS, and Linux computers, as well as phones and tablets running iOS or Android. It supports wired headphones and headsets (including models with in-line controls), making it an ideal solution for using existing audio gear and eliminating the need for Bluetooth audio solutions.
  • Sleek and Portable Design
    The compact, sleek adapter measures just 5 inches (127mm) and features a flexible and durable TPE jacket with a soft-touch finish. Use this adapter cable on the go or at a workstation for audio playback, recording, or calls.
StarTech.com USB-C Audio Adapter to 3.5mm TRRS Jack, Headphone Aux Dongle - USB-C to headphone jack adapter - 12.7 cm
Cable
Length
12.7 cm
Connector
24 pin USB-C - male
Connector (Second End)
4-pole mini jack - female
USB / USB 2.0
DAC
DAC Details
44.1 - 384 kHz - SNR: 105 dB
32-bit DAC, Realtek ALC4030U chipset
Cable Type
Jacket Material
Thermoplastic elastomer (TPE)
USB / USB 2.0
Length
12.7 cm
Recommended Use
Laptop, phone, tablet
Adapters & Converters
Audio Output
Stereo
DAC
Frequency Response
44.1 - 384 kHz
Signal-To-Noise Ratio
105 dB
Microsoft Windows 10 / 11, Apple macOS Sequoia 15.0, Apple macOS Sonoma 14.0, Apple macOS Ventura 13.0, Apple iPadOS, Apple iOS, Android
Connector
24 pin USB-C - male
Mini-phone 3.5 mm 4-pole - female
RoHS, WEEE, CTIA, OMTP
9 g
Shipping Width
22 cm
Shipping Depth
18 cm
Shipping Height
1.2 cm
Shipping Weight
15 g
J4KN StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
J4KN StarTech.com Slim Stereo Splitter Cable - 3.5mm Male to 2x 3.5mm Female In Stock £4.76
J4KN StarTech.com 1m Slim 3.5mm Stereo Extension Audio Cable - M/F In Stock £5.46
J4KN StarTech.com 1m White Slim 3.5mm Stereo Audio Cable - Male to Male In Stock £3.22
