StarTech.com USB C Adapter - 4K HDMI, GbE
Quicklinx: CVXRWS00 Mfr#: DKT30CHD
More than 50 in stock
£45.51 ex VAT
£54.61 inc VAT
Add HDMI, Gigabit Ethernet, USB-A, and USB-C ports (5Gbps) to your laptop through a single USB Type-C cable. Expand the connectivity of your USB-C equipped laptop, wherever you go. With this USB-C adapter, you can create a powerful workstation, providing support for an Ultra HD 4K monitor, a wired network connection, USB-A device and a USB-C device.
Ideal for mobile use, the USB-C multiport adapter is the perfect accessory for your Dell Precision, Dell XPS, MacBook or other USB Type-C laptop. Since it uses USB-C, the adapter is Thunderbolt 3 port compatible, to connect to your Thunderbolt 3 equipped laptop.
When coupled with your laptop, this USB-C adapter makes it easy to set up a dual-monitor workstation. It offers an HDMI port that supports 4K Ultra HD 4096 x 2160p with audio to connect a high-resolution monitor, plus it supports 3840 x 2160p resolution. When traveling, you can use an HDMI port-equipped television in a hotel room as a second display. The travel adapter is also ideal for quick setups in conference rooms or boardrooms, to deliver engaging presentations.
The USB-C multiport adapter ensures reliable wired network access with a Gigabit Ethernet port, which is ideal for areas with limited Wi-Fi access such as in classrooms, office buildings and hotels.
The multiport adapter provides a versatile way to connect USB devices to your port-limited laptop. Connect an existing device, like your mouse or a flash drive, to the USB Type-A port. With the USB-C port, you are future-ready to add a USB-C device.
The bus-powered multiport adapter is portable and compact, tucking easily your laptop bag. Since it consolidates multiple ports into a single adapter, you don't need to bring along multiple single-function adapters. The adapter also features a built-in USB-C cable, which means one less cable to carry. Installation is fast and simple, with native support in most operating systems.
Note: Your USB-C equipped host laptop must support video (DP Alt Mode) to work with this adapter. The adapter does not support USB Power Delivery.
StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI / USB 3.0 / Gigabit Ethernet - Powered USB Hub - USB-C to USB Adapter (DKT30CHD) - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
4096 x 2160
HDMI , USB-C (female connector) , Network (RJ-45) , USB 3.0
Enclosure Colour
3-year warranty
Bus Type
USB-C
Max Resolution
4096 x 2160 at 24 Hz
USB powered, HD/4k Ready
Google Chrome OS, Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.10 - 10.12
FCC, RoHS
Enclosure Colour
TAA Compliant
Limited warranty - 3 years
60 °C
5 - 90% (non-condensing)
CVXR StarTech.com USB-C Multifunction Adapter 4K In Stock £47.48
CVXR StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £34.85
CVXR StarTech.com USB-C to VGA Adapter with PD In Stock £30.79
CVXR StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £32.88
CVXR StarTech.com USB-C Adapter - PD - Silver In Stock £57.41
CVXR StarTech.com USB C Adapter - 4K HDMI, GbE In Stock £45.51
CVXR StarTech.com USB-C Multiport Adapter - DVI In Stock £48.66
CVXR StarTech.com USB-C Multiport Adapter - HDMI In Stock £48.65
Price Range Ex VAT: 0 - 50
