StarTech.com USB C Adapter - 4K HDMI, GbE
Quicklinx: CVXRWS00 Mfr#: DKT30CHD
37 In Stock
£28.65 ex VAT
£34.38 inc VAT
Add HDMI, Gigabit Ethernet, USB-A, and USB-C ports (5Gbps) to your laptop through a single USB Type-C cable. Expand the connectivity of your USB-C equipped laptop, wherever you go. With this USB-C adapter, you can create a powerful workstation, providing support for an Ultra HD 4K monitor, a wired network connection, USB-A device and a USB-C device.
Ideal for mobile use, the USB-C multiport adapter is the perfect accessory for your Dell Precision, Dell XPS, MacBook or other USB Type-C laptop. Since it uses USB-C, the adapter is Thunderbolt 3 port compatible, to connect to your Thunderbolt 3 equipped laptop.
When coupled with your laptop, this USB-C adapter makes it easy to set up a dual-monitor workstation. It offers an HDMI port that supports 4K Ultra HD 4096 x 2160p with audio to connect a high-resolution monitor, plus it supports 3840 x 2160p resolution. When traveling, you can use an HDMI port-equipped television in a hotel room as a second display. The travel adapter is also ideal for quick setups in conference rooms or boardrooms, to deliver engaging presentations.
The USB-C multiport adapter ensures reliable wired network access with a Gigabit Ethernet port, which is ideal for areas with limited Wi-Fi access such as in classrooms, office buildings and hotels.
The multiport adapter provides a versatile way to connect USB devices to your port-limited laptop. Connect an existing device, like your mouse or a flash drive, to the USB Type-A port. With the USB-C port, you are future-ready to add a USB-C device.
The bus-powered multiport adapter is portable and compact, tucking easily your laptop bag. Since it consolidates multiple ports into a single adapter, you don't need to bring along multiple single-function adapters. The adapter also features a built-in USB-C cable, which means one less cable to carry. Installation is fast and simple, with native support in most operating systems.
Note: Your USB-C equipped host laptop must support video (DP Alt Mode) to work with this adapter. The adapter does not support USB Power Delivery.
  • Add a 4K UHD Monitor
    With HDMI output, this USB-C multiport adapter makes it easy to expand your virtual workspace onto an external 4K HDMI monitor. The adapter supports resolutions up to 4096 x 2160p (24Hz) or 3840 x 2160p (30Hz), as well as audio.
  • Reliable Network Access
    The USB-C multiport adapter ensures a reliable wired network connection with a Gigabit Ethernet port, which is ideal for areas with limited Wi-Fi access such as in classrooms, office buildings and hotels.
  • Connect Your USB Devices Easily
    With two USB 3.0 ports (1x USB-A, 1x USB-C) you get access to traditional USB Type-A devices, as well as newer USB-C devices you add in the future.
  • Bring Productivity with You Wherever You Go
    With its compact design and bus-powered performance, the portable multiport adapter is easy to take with you anywhere you take your laptop. The adapter features a pre-attached USB-C cable, so you have one less cable to carry when you're on the move.
  • The StarTech.com Advantage for Docking Stations
    • Maximum compatibility - StarTech.com has a docking station to fit every operating system, laptop brand, and connectivity need •Text | Get more done faster - More ports and more displays maximize end user connectivity and productivity •Text | Quick installation - eliminate deployment headaches that waste time and frustrate end users •Text | IT Grade quality - trusted by IT pros around the world for our rigorous in-house product testing, robust compliance, and lifetime multilingual technical support The DKT30CHD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: Your USB-C equipped host laptop must support video (DP Alt Mode) to work with this adapter. The adapter does not support USB Power Delivery.
StarTech.com USB C Multiport Adapter, Portable USB-C Mini Dock 4K HDMI Video, Gigabit Ethernet, USB 3.0 Hub (1x USB-A 1x USB-C), USB Type-C Multiport Adapter, Thunderbolt 3 Compatible - USB-C Travel Dock (DKT30CHD) - docking station - USB-C / Thunderbolt 3 - HDMI - 1GbE - TAA Compliant
Docking station
Docking Interface
Video Interfaces
HDMI
6.2 cm x 6.5 cm x 1.5 cm
52 g
Gigabit Ethernet
TAA Compliant
3-year warranty
Docking station
6.2 cm
6.5 cm
1.5 cm
52 g
Enclosure Colour
Video
Max Resolution Details
4096 x 2160 - 24 Hz , 3840 x 2160 - 30 Hz
Gigabit Ethernet
USB 3.0, USB 3.1 Gen 1
1 x USB-C 3.1 Gen 1 - 24 pin USB-C , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C cable - integrated - 34 cm
USB powered, full duplex support, auto MDIX support, plastic housing
FCC, RoHS, UASP (USB Attached SCSI Protocol)
TAA Compliant
Google Chrome OS, Apple MacOS X 10.10 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
Shipping Width
14.5 cm
Shipping Depth
21 cm
Shipping Height
4 cm
Shipping Weight
168 g
CVXR StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £14.29
CVXR StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £9.84
CVXR StarTech.com USB-C Multifunction Adapter In Stock £53.48
CVXR StarTech.com USB-C to 4K HDMI Adapter with Power Delivery In Stock £50.29
CVXR StarTech.com USB-C to VGA Adapter with PD In Stock £40.42
CVXR StarTech.com 2m 6ft USB 2.0 USB-C Cable In Stock £11.21
CVXR StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.53
CVXR StarTech.com USB-C Adapter - PD - Silver In Stock £29.65
CVXR StarTech.com 4m USB 2.0 C Cable w/ PD (5A) In Stock £17.50
CVXR StarTech.com 0.5m USB 2.0 USB C Cable In Stock £9.87
CVXR StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £21.34
CVXR StarTech.com 1m USB 3.1 C Cable w/ PD (5A) In Stock £26.86
CVXR StarTech.com USB C Adapter - 4K HDMI, GbE In Stock £28.65
CVXR StarTech.com USB-C Multiport Adapter - DVI In Stock £27.69
CVXR StarTech.com 1m Right Angle USB C Cable In Stock £11.94
CVXR StarTech.com 3m USB 2.0 Type C Cable In Stock £13.47
CVXR StarTech.com USB-C Multiport Adapter Docking Station In Stock £134.19
CVXR StarTech.com USB-C Multiport Adapter with Unfolding Cable - HDMI1.4 - USB In Stock £41.62
CVXR StarTech.com USB-C Adapter with HDMI & VGA In Stock £33.69
CVXR StarTech.com USB-C Multiport Adapter, 4K HDMI or VGA, Type-C Mini Dock In Stock £67.41
CVXR StarTech.com USB C Multiport Adapter - USB-C to 4K HDMI/PD/USB -Mini Dock In Stock £25.35
CVXR StarTech.com USB C Multiport Adapter 4K In Stock £33.71
CVXR StarTech.com USBC Multiport Adapter 4K HDMI In Stock £29.51
CVXR StarTech.com USB C Multiport Adapter PD, 4K In Stock £22.60
CVXR StarTech.com USB-C Multiport Adapter HDMI In Stock £59.78
CVXR StarTech.com USB C Multiport Adapter In Stock £25.36
CVXR StarTech.com Multiport Adapter HDMI/VGA In Stock £63.79
CVXR StarTech.com USB C Multiport Adapter, 4K In Stock £34.56
CVXR StarTech.com USB C Multiport Adapter 4K In Stock £49.33
CVXR StarTech.com USB C Mini Dock 4K HDMI In Stock £42.13
CVXR StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £49.61
CVXR StarTech.com USB C Multiport Adapter 2 HDMI In Stock £73.26
CVXR StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £32.39
CVXR StarTech.com USB C Dock DP 4K30Hz or VGA In Stock £102.07
CVXR StarTech.com USB-C Multiport Adapter In Stock £75.26
CVXR StarTech.com USB C Multiport Adapter In Stock £91.68
CVXR StarTech.com USB-C Multiport Adapter, HDMI In Stock £35.29
CVXR StarTech.com USB-C Multiport Adapter, HDMI In Stock £30.28
CVXR StarTech.com USB-C Triple Monitor Docking Station In Stock £179.82
CVXR StarTech.com USB-C Multiport Adapter - HDMI/DP In Stock £43.01
CVXR StarTech.com USB-C Multiport Adapter - HDMI/VGA In Stock £27.91
CVXR StarTech.com USB-C Speakerphone Dock In Stock £86.00
CVXR StarTech.com USB-C Triple-Monitor Adapter In Stock £93.58
CVXR StarTech.com USB-C/USB-A Multiport Adapter In Stock £51.56
CVXR StarTech.com USB-C Triple-Monitor Adapter In Stock £104.61
