StarTech.com USB 3.1 USB-C to USB-A Adapter
Quicklinx: BFPCWS00 Mfr#: USB31CAADP
More than 50 in stock
£9.71 ex VAT
£11.65 inc VAT
Connect your USB Type-C device to a USB Type-A device, with this durable adapter. Have you purchased a new device that only came equipped with a USB Type-C or Thunderbolt 3 port, such as a laptop or tablet? Do you need to connect to older USB 3.0 or 2.0 devices?
This USB-C to USB-A adapter makes it easy to connect USB 3.0 and 2.0 devices to new USB-C devices. Simply plug the adapter into the USB Type-C port to turn it into a USB Type-A port, and you're ready to connect your older devices. The adapter is compatible with USB 3.0 enabled computers, such as the Dell Latitude 11 5000 2-in-1, and more.
USB 3.0 is also known as USB 3.1 Gen 1 (5Gbps).
StarTech.com USB-C to USB Adapter - 6in - USB-IF Certified - USB-C to USB-A - USB 3.1 Gen 1 - USB C Adapter - USB Type C (USB31CAADP) - USB-C adapter - USB-C to USB Type A - 15.2 cm
USB-C adapter
Double shielded
Length
15.2 cm
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type A - female
USB 3.0
Works With Chromebook
P/N: ARMTBLTDT, BNDDKT30CAHV, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, HB30A3A1CST, HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC2, PEXUSB311AC3, PEXUSB312C2, ST4300MINI, TB33A1C, USBA2DPGB
USB-C adapter
Double shielded
Plated Connector
Nickel
Length
15.2 cm
Connector
24 pin USB-C - male
USB 3.0, RoHS, USB-IF
P/N: ARMTBLTDT, ARMTBLTIW, ARMTBLTUGN, BNDDKT30CAHV, DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, HB30A3A1CFB, HB30A3A1CSFS, HB30A3A1CST, HB30C3A1CFB, HB30C3A1CFS, HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC2, PEXUSB311AC3, PEXUSB312C2, PEXUSB312EIC, SECTBLTPOS, ST3300G3UA, ST43004UA, ST4300MINI, ST73007UA, STNDTBLT1A5T, STNDTBLT1FS, TB33A1C, USB31GEHD, USB31GEVG, USB3DDOCKFT, USB3DOCKH2DP, USB3DOCKHDPC, USB3SDOCKD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV, USB3SMDOCK4K, USB3SMDOCKHV, USB3VDOCK4DP, USB3VDOCKD, USBA2DPGB
BFPC StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.71
BFPC StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
BFPC StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £11.02
BFPC StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.39
BFPC StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £7.11
BFPC StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £12.74
BFPC StarTech.com 1m 3ft USB 3.1 C to B Cable In Stock £15.83
Stock Status: In stock
