Connect a 2.5" SATA SSD/HDD to your computer using this USB 3.1 Gen 2 ultra-portable cable. Here's a fast, easy way to access data on a 2.5" solid-state or hard drive. This cable-style adapter lets you connect your laptop or desktop computer directly to a solid-state drive and access it through ultra-fast USB 3.1 Gen. 2 (up to 10 Gbps).
With the adapter cable, you can quickly swap hard drives without having to install your drives into an enclosure. You can copy or retrieve data from a 2.5" SSD/HDD quickly with no additional accessories required. It gives you easy drive access for data migration, drive cloning and data backup applications, with the fast performance of USB 3.1 Gen 2.
USB 3.1 Gen 2 gives you greater bandwidth and speed with rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
This cable-style adapter features a compact, lightweight design that tucks easily into a laptop bag or carrying case. Use it wherever you go to access valuable data quickly - with no external power required.
- StarTech.com USB 3.1 to 2.5" SATA Hard Drive Adapter - USB 3.1 Gen 2 10Gbps with UASP External HDD/SSD Storage Converter (USB312SAT3CB) - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
- Storage controller - external
- Bus Type
- USB 3.1 (Gen 2)
- Black
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Product Material
- Plastic
- 4.5 cm x 51.5 cm x 8 mm
- 30.5 g
- 2-year warranty
- 2.5"
- Host Bus
- USB 3.1 (Gen 2)
- Product Material
- Plastic
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Processor
- ASMedia ASM1351
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 9 pin USB Type A
- Cables Included
- 1 x USB cable - integrated
- USB powered, UASP transfer protocol, tested with up to 2TB 7200 RPM 2.5" hard drives
- FCC, RoHS
- Limited warranty - 2 years
- 4.5 cm
- 51.5 cm
- 8 mm
- 30.5 g
- 0 °C
- 70 °C
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.36 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £98.93 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.56 |
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £44.16 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £9.09 |
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) | In Stock | £56.59 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £18.77 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £19.82 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £48.34 |
StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable | In Stock | £28.65 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £71.32 |
StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £111.14 |
StarTech.com USB 3.1 Gen 2 Single-bay Dock | In Stock | £53.41 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £86.55 |
StarTech.com USB 3.1 Gen 2 Adapter Cable | In Stock | £15.34 |
StarTech.com USB 3.1 Adapter Cable w/ USB-C | In Stock | £19.17 |
StarTech.com 10 Port Industrial USB 3.0 Hub | In Stock | £131.31 |
StarTech.com 10-Pt USB 3.0 Hub w/ Charging | In Stock | £64.54 |
StarTech.com 4-Port USB 3 Hub + 2.4A DCP | In Stock | £43.24 |
StarTech.com 7-Pt USB 3.0 Hub + Charge Pts | In Stock | £60.12 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £28.58 |
StarTech.com USB 3.1 / eSATA 1-bay Dock | In Stock | £55.98 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £19.20 |
StarTech.com CFast Card Reader - USB 3.0 | In Stock | £22.25 |
StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £44.43 |
StarTech.com CFast Card Reader - USB-C | In Stock | £28.27 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £36.75 |
StarTech.com 4PT USB 3.0 Hub - Charge Port | In Stock | £34.82 |
StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C | In Stock | £29.22 |
