Dock your 2.5" or 3.5" SATA drive over high performance USB 3.1 with UASP. Unleash the power of USB 3.1 Gen 2 (10 Gbps) with this single-drive docking station. It supports both 2.5" and 3.5" form factors for solid-state and hard drives, with a high drive capacity of 6TB.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
It's never been easier to dock and swap drives from your desktop computer or laptop. Simply insert your drives into the top loading slot, with no tools or trays required. The HDD ejection button allows fast and simple drive removal.
The docking station comes with a USB Type-A to B cable, providing backward compatibility with your existing USB 3.0, 2.0 and 1.x devices. It also supports UASP for enhanced performance.
Efficient hot-swap capability
The docking station enables users to exchange drives on the fly, minimizing downtime during data management and enhancing productivity. -
High-speed data transfer
With USB 3.1 (Gen 2) and UASP transfer protocol, this dock provides faster data speeds, allowing for quick and efficient file transfers. -
Versatile hard drive compatibility
The device supports both 2.5" and 3.5" hard drives, accommodating a wide range of storage solutions for various needs. -
Clear operational indicators
Equipped with LED indicators for data and power, users can easily monitor the status of the docking station and connected drives. -
Reliable build quality
Constructed from durable plastic, this docking station is designed to withstand regular use while maintaining performance.
- StarTech.com USB 3.1 (10Gbps) Single-Bay Dock for 2.5"/3.5" SATA SSD/HDD - USB 3.1 Hard Drive Docking Station with UASP (SDOCKU313) - storage controller - USB 3.1 (Gen 2)
- Storage controller - external
- Bus Type
- USB 3.1 (Gen 2)
- Black
- Expansion Bays
- 1 x hot-swap - 2.5" / 3.5" shared
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Data indicator, power indicator
- Supported Devices
- Hard drive, solid state drive
- Product Material
- Plastic
- Power
- AC 120/230 V
- 9.3 cm x 14.5 cm x 6.52 cm
- 400 g
- 2-year warranty
- 2.5", 3.5"
- Host Bus
- USB 3.1 (Gen 2)
- Product Material
- Plastic
- Black
Storage Controller
- Supported Devices
- Processor
- ASMedia ASM1351
- Bays
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 10 pin Micro-USB Type B
- Cables Included
- 1 x USB cable - external , 4 x power connector adaptor - external
- LED indicator, tested with up to 6TB 7200 RPM hard drives, UASP transfer protocol
- FCC, RoHS
- Power adapter
- Voltage Required
- AC 120/230 V
- Limited warranty - 2 years
- 9.3 cm
- 14.5 cm
- 6.52 cm
- 400 g
- 5 °C
- 35 °C
- 20 - 80%
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.33 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £19.65 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £14.55 |
StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M | In Stock | £7.61 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £15.57 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £18.13 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £26.43 |
StarTech.com USB 3.1 Gen 2 Single-bay Dock | In Stock | £53.68 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £82.78 |
StarTech.com USB 3.1 Adapter Cable w/ USB-C | In Stock | £17.59 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £27.05 |
StarTech.com USB 3.1 / eSATA 1-bay Dock | In Stock | £54.05 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £34.82 |
