StarTech.com USB 3.1 Gen 2 Adapter Cable
Quicklinx: BHZ8WS00 Mfr#: USB312SAT3CB
£15.20 ex VAT
£18.24 inc VAT
Connect a 2.5" SATA SSD/HDD to your computer using this USB 3.1 Gen 2 ultra-portable cable. Here's a fast, easy way to access data on a 2.5" solid-state or hard drive. This cable-style adapter lets you connect your laptop or desktop computer directly to a solid-state drive and access it through ultra-fast USB 3.1 Gen. 2 (up to 10 Gbps).
With the adapter cable, you can quickly swap hard drives without having to install your drives into an enclosure. You can copy or retrieve data from a 2.5" SSD/HDD quickly with no additional accessories required. It gives you easy drive access for data migration, drive cloning and data backup applications, with the fast performance of USB 3.1 Gen 2.
USB 3.1 Gen 2 gives you greater bandwidth and speed with rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
This cable-style adapter features a compact, lightweight design that tucks easily into a laptop bag or carrying case. Use it wherever you go to access valuable data quickly - with no external power required.
StarTech.com USB 3.1 to 2.5" SATA Hard Drive Adapter - USB 3.1 Gen 2 10Gbps with UASP External HDD/SSD Storage Converter (USB312SAT3CB) - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage controller - external
Bus Type
USB 3.1 (Gen 2)
Hard Drive Form Factor Compatibility
2.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Product Material
Plastic
4.5 cm x 51.5 cm x 8 mm
30.5 g
2.5"
Host Bus
USB 3.1 (Gen 2)
Product Material
Plastic
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
ASMedia ASM1351
1 x SATA 6Gb/s - SATA combo
1 x USB 3.1 (Gen 2) - 9 pin USB Type A
1 x USB cable - integrated
USB powered, UASP transfer protocol, tested with up to 2TB 7200 RPM 2.5" hard drives
FCC, RoHS
4.5 cm
51.5 cm
8 mm
30.5 g
70 °C
BHZ8 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.30
BHZ8 StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £98.93
BHZ8 StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.56
BHZ8 StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £39.12
BHZ8 StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £9.09
BHZ8 StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £52.09
BHZ8 StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter In Stock £16.17
BHZ8 StarTech.com mSATA SSD to 2.5in SATA Adapter Converter In Stock £18.55
BHZ8 StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £48.34
BHZ8 StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable In Stock £24.61
BHZ8 StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £63.50
BHZ8 StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £111.14
BHZ8 StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.41
BHZ8 StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £84.45
BHZ8 StarTech.com USB 3.1 Gen 2 Adapter Cable In Stock £15.20
BHZ8 StarTech.com USB 3.1 Adapter Cable w/ USB-C In Stock £19.17
BHZ8 StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £133.39
BHZ8 StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £64.54
BHZ8 StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £43.24
BHZ8 StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £57.36
BHZ8 StarTech.com USB 3.1 2.5/3.5" SATA Adapter In Stock £27.56
BHZ8 StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £55.00
BHZ8 StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £19.60
BHZ8 StarTech.com CFast Card Reader - USB 3.0 In Stock £22.25
BHZ8 StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £40.59
BHZ8 StarTech.com CFast Card Reader - USB-C In Stock £28.27
BHZ8 StarTech.com USB C to SATA Adapter Cable In Stock £35.55
BHZ8 StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £31.45
BHZ8 StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C In Stock £26.46
