Easily access, transfer and backup data from a SATA drive to your PC or laptop, through USB 3.1. This USB 3.1 to SATA adapter gives you fast and easy access to the data on your 2.5 in./3.5 in. solid-state drives and hard drives. The adapter cable lets you connect your laptop or desktop computer directly to a SATA drive and access it through ultra-fast USB 3.1 Gen. 2 (up to 10Gbps).
This adapter cable lets you quickly swap your drives. You can copy or retrieve data from your 2.5 in. or 3.5 in. SATA drive, with no additional accessories required.
The tool-free adapter cable is ideal for IT technicians who need fast access to SATA drives. It's the perfect solution for data migration, drive cloning, and data backup or recovery applications, providing the fast performance of USB 3.1 Gen 2. You can also operate multiple adapters at the same time, when you require simultaneous access to many drives.
USB 3.1 Gen 2 gives you greater bandwidth and speed with rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
The compact, lightweight design of the USB 3.1 to SATA adapter provides easy portability. The adapter features an integrated 1 m cable, so you never to worry about forgetting to bring your connector cable with you.
You can connect easily to a 2.5 in. solid-state drive or hard drive, using USB power, with no external power required. A universal power adapter is included for use when connecting to your 3.5 in. drives or for any 2.5 in. drives that may require additional power.
Efficient Data Transfer
The adapter supports USB 3.1 Gen 2 interface, allowing data transfer rates of up to 10 Gbps for enhanced productivity and quick file access. -
Versatile Compatibility
It works with both 2.5 inch and 3.5 inch drives, providing users flexibility to connect various storage devices effortlessly. -
Reliable Operation
Designed to operate in a range of temperatures from 0°C to 60°C and humidity levels of 0 to 80%, ensuring dependable use across different environments. -
User-Friendly Features
The integrated LED indicator helps users monitor the connection status, making functionality straightforward and intuitive. -
Compliant with Standards
This product meets FCC and RoHS standards, promoting safe and environmentally conscious usage.
- StarTech.com USB to SATA Adapter Cable - 2.5in and 3.5in Drives - USB 3.1 - 10Gbps - External Hard Drive Cable - Hard Drive Adapter Cable (USB312SAT3) - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
- Storage controller - external
- Bus Type
- USB 3.1 (Gen 2)
- Black
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 6 Gbit/s
- Supported Devices
- Hard drive, solid state drive
- Power
- AC 120/230 V
- 2.45 cm x 8.5 cm x 2.1 cm
- 80 g
- 2-year warranty
- 2.5", 3.5"
- Host Bus
- USB 3.1 (Gen 2)
- Black
Storage Controller
- Interface
- SATA 6Gb/s
- 6 Gbit/s
- Supported Devices
- Processor
- ASMedia ASM1351
- 1 x SATA 6Gb/s - SATA combo
- Connections
- 1 x USB 3.1 (Gen 2) - 9 pin USB Type A
- Cables Included
- 1 x USB cable - integrated
- LED indicator, UASP transfer protocol
- FCC, RoHS
- Power adapter
- Voltage Required
- AC 120/230 V
- Limited warranty - 2 years
- 2.45 cm
- 8.5 cm
- 2.1 cm
- 80 g
- 0 °C
- 60 °C
- 0 - 80%
StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap | In Stock | £3.30 |
StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) | In Stock | £12.52 |
StarTech.com M.2 NGFF SSD to 2.5in SATA Adapter Converter | In Stock | £16.20 |
StarTech.com mSATA SSD to 2.5in SATA Adapter Converter | In Stock | £18.80 |
StarTech.com USB 3.1 Gen 2 Single-bay Dock | In Stock | £53.41 |
StarTech.com USB 3.1 Gen 2 Dual-bay Dock | In Stock | £84.45 |
StarTech.com USB 3.1 Gen 2 Adapter Cable | In Stock | £15.20 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £28.00 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £11.96 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £36.11 |
StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C | In Stock | £26.46 |
