StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter for Mac and PC
Price Drop!
Last Few Remaining
Price Drop
Quicklinx: 97QLWS00 Mfr#: USB32VGAPRO
10 in stock
£54.99 ex VAT
£65.98 inc VAT
Connect a VGA monitor or projector through USB 3.0, for an external multi-monitor solution at resolutions up to 1920x1200. The USB32VGAPRO USB 3.0 to VGA Adapter turns an available USB 3.0 port on your desktop or laptop into a VGA output, with high resolution 1920x1200/1080p video support - a convenient external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled Mac or PC (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, and powered by the DisplayLink chipset, the USB32VGAPRO is the highest performing USB to VGA adapter, delivering high-resolution content to your VGA-capable display. The external graphics card can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com USB 3.0 to VGA External Video Card Adapter for Mac and PC - external video adapter - DisplayLink DL-3100N - 512 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
512 MB DDR2
Max Resolution
1920 x 1200
VGA
5.5 cm 2 cm
Length
25.5 cm
Enclosure Colour
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
1920 x 1200
VGA
USB powered
Size
512 MB
DDR2 SDRAM
Ubuntu 14.04, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Ubuntu 16.04, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Apple macOS Mojave 10.14
Min Processor Type
Quad core processor 2.4 GHz
Min RAM Size
4 GB
Additional Requirements
USB port
1 x USB cable
Software Included
Drivers & Utilities
RoHS
5.5 cm
2 cm
Length
25.5 cm
158 g
Enclosure Colour
10 °C
0 - 85% (non-condensing)
97QL StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
97QL StarTech.com 6 ft Monitor VGA Cable - HD15 M/M In Stock £4.11
97QL StarTech.com USB to VGA Multi Monitor External Video Adapter In Stock £31.82
97QL StarTech.com 10 ft VGA Monitor Cable - HD15 MM In Stock £4.46
97QL StarTech.com 15 ft Monitor VGA Cable - HD15 MM In Stock £5.03
97QL StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 In Stock £35.66
97QL StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter with 1-Port USB Hub 1920x1200 In Stock £40.35
97QL StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter for Mac and PC In Stock £54.99
97QL StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £39.07
97QL StarTech.com USB 3.0 VGA Video Adapter In Stock £34.20
Price Range Ex VAT: 50 - 100
