StarTech.com USB 3.0 VGA Video Adapter
PRICE DROP!
Last Few Remaining
Price Drop
Quicklinx: B683WS00 Mfr#: USB32VGAV
12 In Stock
£17.63 ex VAT
£21.15 inc VAT
Add a secondary VGA display to your USB 3.0 enabled PC, and install the drivers without a CD or Internet connection. This USB 3.0 to VGA video adapter works as an external video card, enabling the USB port on your computer to output video to a VGA display at high resolution. The adapter also features on-board driver installation, which means the adapter will work when you connect it, even without a software disc or Internet connection. For the ultimate in hassle-free installation, this USB video adapter features on-board drivers which prompts for installation as soon as you connect the adapter to your Ultrabook or laptop computer. This means you can maximize portability by never requiring an installation disc or Internet connection to install the device.
Adding a second or third display to your computer can vastly increase your productivity by giving the freedom to access more applications at the same time. This video adapter is intended to support all of your business applications including web browsing. You can also leave your system video card available for more demanding applications such as gaming or CAD design, while you use the USB monitor for reference material. Using the high-bandwidth USB 3.0 interface, this adapter enables smoother scrolling through documents, higher refresh rates and an overall enhanced performance over USB 2.0. The adapter is optimized for use with USB 3.0, but for added compatibility this adapter is also backward compatible with USB 2.0 computer systems.
  • High Resolution Support
    The adapter provides maximum output resolution of 1920 x 1200, ensuring crisp and clear visuals for presentations and other applications.
  • Broad Compatibility
    Designed to work seamlessly with both USB 2.0 and USB 3.0 standards, allowing versatile connections with various devices.
  • Easy Connectivity
    Equipped with a 9-pin USB Type-A male connector and a 15-pin HD D-Sub female connector, enabling straightforward Plug-and-Play setup.
StarTech.com USB 3.0 to VGA Display Adapter 1920x1200, On-Board Driver Installation, Video Converter with External Graphics Card - Windows (USB32VGAV) - USB / VGA adapter - USB Type A to HD-15 (VGA) - 19.5 m
USB / VGA adapter
1920 x 1200 (WUXGA) support
Length
19.5 m
Connector
9 pin USB Type A - male (input)
Connector (Second End)
15 pin HD D-Sub (HD-15) - female
USB / USB 2.0 / USB 3.0
P/N: MXT101MM
USB / VGA adapter
Length
19.5 m
2.5 cm
1.2 cm
9.3 g
Connector
USB / USB 2.0 / USB 3.0, FCC, RoHS
Shipping Width
14.3 cm
Shipping Depth
17.2 cm
Shipping Height
3 cm
Shipping Weight
92 g
P/N: MXT101MM
B683 StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 In Stock £14.94
B683 StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £19.04
B683 StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £57.25
B683 StarTech.com USB 3.0 VGA Video Adapter In Stock £17.63
B683 StarTech.com USB 3.0 to HDMI VGA Adapter - 4K 30 - External Video & Graph In Stock £62.06
