StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter for Mac and PC
PRICE DROP!
Last Few Remaining
Price Drop
Quicklinx: 97QLWS00 Mfr#: USB32VGAPRO
Hurry, only 2 left in stock!
£24.96 ex VAT
£29.95 inc VAT
Connect a VGA monitor or projector through USB 3.0, for an external multi-monitor solution at resolutions up to 1920x1200. The USB32VGAPRO USB 3.0 to VGA Adapter turns an available USB 3.0 port on your desktop or laptop into a VGA output, with high resolution 1920x1200/1080p video support - a convenient external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled Mac or PC (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, and powered by the DisplayLink chipset, the USB32VGAPRO is the highest performing USB to VGA adapter, delivering high-resolution content to your VGA-capable display. The external graphics card can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com USB 3.0 to VGA Display Adapter 1920x1200 1080p, DisplayLink Certified, Video Converter w/ External Graphics Card - Mac & PC (USB32VGAPRO) - USB / VGA adapter - USB Type A to HD-15 (VGA) - 25.5 m
USB / VGA adapter
1920 x 1200 (WUXGA) support
Length
25.5 m
Connector
9 pin USB Type A - male (input)
Connector (Second End)
15 pin HD D-Sub (HD-15) - female
USB / USB 2.0 / USB 3.0
P/N: MXT101MM
USB / VGA adapter
Length
25.5 m
5.5 cm
2 cm
64 g
Connector
USB / USB 2.0 / USB 3.0, FCC, RoHS, DisplayLink Plug and Display
Shipping Width
14.6 cm
Shipping Depth
21.2 cm
Shipping Height
4 cm
Shipping Weight
158 g
P/N: MXT101MM
97QL StarTech.com USB to VGA Multi Monitor External Video Adapter In Stock £15.77
97QL StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 In Stock £12.18
97QL StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter for Mac and PC In Stock £24.96
97QL StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £19.75
97QL StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £49.78
97QL StarTech.com USB 3.0 VGA Video Adapter In Stock £17.38
97QL StarTech.com USB 3.0 to HDMI VGA Adapter - 4K 30 - External Video & Graph In Stock £63.24
