Connect a VGA monitor or projector through USB 3.0, for an external multi-monitor solution at resolutions up to 1920x1200. The USB32VGAPRO USB 3.0 to VGA Adapter turns an available USB 3.0 port on your desktop or laptop into a VGA output, with high resolution 1920x1200/1080p video support - a convenient external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled Mac or PC (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, and powered by the DisplayLink chipset, the USB32VGAPRO is the highest performing USB to VGA adapter, delivering high-resolution content to your VGA-capable display. The external graphics card can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
- StarTech.com USB 3.0 to VGA Display Adapter 1920x1200 1080p, DisplayLink Certified, Video Converter w/ External Graphics Card - Mac & PC (USB32VGAPRO) - USB / VGA adapter - USB Type A to HD-15 (VGA) - 25.5 m
- USB / VGA adapter
- 1920 x 1200 (WUXGA) support
- Length
- 25.5 m
- Connector
- 9 pin USB Type A - male (input)
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - female
- USB / USB 2.0 / USB 3.0
- Black
- 2-year warranty
- Designed For
- P/N: MXT101MM
- USB / VGA adapter
- Length
- 25.5 m
- Black
- 5.5 cm
- 2 cm
- 64 g
- Connector
- USB / USB 2.0 / USB 3.0, FCC, RoHS, DisplayLink Plug and Display
- Shipping Width
- 14.6 cm
- Shipping Depth
- 21.2 cm
- Shipping Height
- 4 cm
- Shipping Weight
- 158 g
- 2-year warranty
- Designed For
- P/N: MXT101MM
StarTech.com USB to VGA Multi Monitor External Video Adapter | In Stock | £15.77 |
StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 | In Stock | £12.18 |
StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £19.75 |
StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC | In Stock | £49.78 |
StarTech.com USB 3.0 VGA Video Adapter | In Stock | £17.38 |
StarTech.com USB 3.0 to HDMI VGA Adapter - 4K 30 - External Video & Graph | In Stock | £63.24 |
