Connect both IDE and SATA hard drives using top slot-loading bays through USB 3.0.
The UNIDOCK3UGB USB 3.0 to SATA/IDE Hard Drive Docking Station delivers instant access to 2.5-inch and 3.5-inch IDE and SATA hard drives through two top loading drive slots - one for Serial ATA drives and one for IDE drives - instead of having to mount the drives into a computer or external enclosure/tray.
The slot-loading design holds the SATA and IDE drive(s) upright inside the docks, neatly keeping them off the desk, for convenience and a clutter-free setup. For SATA drives, the HDD can be inserted and connected directly through the designated dock slot, while the IDE drive slot is conveniently positioned near the rear panel 40-pin data and LP4 power connections, making it easy to connect to the dock using the included IDE data and power cables.
Connected to the host computer through a single USB 3.0 connection, both an IDE hard drive and a SATA hard drive (SATA, SATA II, SATA III) can be connected to the HDD dock simultaneously - a convenient solution for migrating data from an IDE drive to a SATA drive or vice versa, or simply harnessing fast and simple access to the contents on both hard drives. Large capacity drives (tested with up to 4TB) can be used to greatly enhance your computer's storage/backup capabilities.
- StarTech.com USB 3.0 to SATA IDE HDD Docking Station for 2.5in or 3.5in Hard Drive - HDD docking station - ATA / SATA 6Gb/s - USB 3.0
- HDD docking station - external
- Bays
- 2
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 2 x hot-swap - 2.5" / 3.5" shared
- Hard Drive Form Factor Compatibility
- 2.5", 3.5"
- Interface
- ATA / SATA 6Gb/s
- Data Transfer Rate
- 500 MBps
- Supported Devices
- Hard drive
- Product Material
- Plastic
- Power
- AC 120/230 V
- System Requirements
- Linux, Microsoft Windows 2000, Apple MacOS X or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
- 13 cm x 14 cm x 7 cm
- 0.61 kg
- 2-year warranty
- Bays
- 2
- 2.5", 3.5"
- Host Bus
- USB 3.0
- Product Material
- Plastic
- Black
Storage Controller
- Interface
- ATA / SATA 6Gb/s
- 500 MBps
- Supported Devices
- Hard drive
- Processor
- JMicron JMS551
- Bays
- 1 x SATA 6Gb/s , 1 x ATA
- Connections
- 1 x USB 3.0 - 9 pin USB Type B
- Cables Included
- 1 x USB 3.0 cable - external , 1 x IDE cable , 1 x power adapter , 2 x power cable , 2 x data cable
- Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
- Plug and Play, FCC, RoHS
- Power adapter
- Voltage Required
- AC 120/230 V
- OS Required
- Limited warranty - 2 years
- 13 cm
- 14 cm
- 7 cm
- 0.61 kg
- 5 °C
- 80 °C
- 8 - 90%
