Add Gigabit Ethernet connectivity and 3 USB 3.0 Hub ports to a computer through a single SuperSpeed USB 3.0 port. The ST3300U3S USB 3.0 Gigabit Network Adapter turns a single SuperSpeed USB 3.0 host connection port into an RJ45 Gigabit network port as well as three additional USB 3.0 hub ports.
Unlike a USB 2.0-based adapter, this USB 3.0-based NIC lets you connect to your home or office network at full Gigabit bandwidth, with support for 10/100/1000Mbps. Plus, with support for features such as Jumbo Frames, VLAN tagging and Wake on LAN (WoL), this versatile network adapter offers a comprehensive Gigabit network solution.
On top of Gigabit Ethernet connectivity, the adapter also adds three USB 3.0 hub ports to your system, which allow you to connect external storage or other USB peripherals locally to the host computer. The hub ports support USB 3.0 speeds of up to 5 Gbps, as well as fast charging for mobile devices (e.g. iPhone, iPad and most Android devices).
Backward compatible with USB 2.0 and USB 1.x standards, the Gigabit Adapter/USB 3.0 hub will still support older USB devices and can also be used with an older system that does not have USB 3.0 ports (network speed limited by USB 1.x/2.0 bus), allowing you to mix and match USB 3.0/2.0/1.x devices. For further portability, the adapters can be used with or without the included external power adapter, eliminating the hassle of having to find an available wall outlet.
- StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White - USB 3 Ethernet Adapter - USB Charging Hub (ST3300U3S) - hub - 3 ports
- Hub - 3 ports
- Subtype
- USB
- Ports
- 3 x SuperSpeed USB 3.0 + 1 x 10/100/1000
- Jumbo Frame Support
- WOL, auto-uplink (auto MDI/MDI-X), VLAN Tagging (not supported in MacOS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, IEEE 802.3az
- Power
- AC 120/230 V
- 7.5 cm x 5.5 cm x 1.5 cm
- 75 g
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 11.3 or later
- 2-year warranty
- Hub - 3 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- Status Indicators
- Power, link/activity
- 3 x USB 3.0 Type A , 1 x micro-USB 3.0 Type B , 1 x 1000Base-T RJ-45
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Cables Included
- 1 x USB cable
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 7.5 cm
- 5.5 cm
- 1.5 cm
- 75 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 85%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £20.74 |
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £38.00 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter | In Stock | £22.54 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter with 3 Port Hub - White | In Stock | £37.08 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter - White | In Stock | £20.53 |
StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter – 10/100/1000 Mbps | In Stock | £20.00 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black | In Stock | £29.25 |
StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White | In Stock | £26.84 |
StarTech.com 3 Port Portable USB 3.0 Hub with Gigabit Ethernet Adapter NIC - Aluminum w/ Cable | In Stock | £38.80 |
StarTech.com 3 Port PCIe USB 3.0 Card + GbE | In Stock | £41.61 |
StarTech.com USB 3.0 Network Adapter-Silver | In Stock | £23.53 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £11.93 |
StarTech.com 3Pt Portable USB 3.0 Hub + GbE | In Stock | £33.70 |
StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop | In Stock | £42.51 |
StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White | In Stock | £25.61 |
StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 | In Stock | £45.82 |
StarTech.com USB to Ethernet Adapter - 1Gb | In Stock | £19.78 |
