Brand
StarTech.com USB 3.0 to Dual HDMI Adapter
Quicklinx: CX91WS00 Mfr#: USB32HD2
More than 50 In Stock
£46.31 ex VAT
£55.57 inc VAT
This USB to HDMI dual monitor adapter lets you add two independent HDMI displays to your computer using a single USB 3.0 port. One of the HDMI ports can output resolutions up to 4K, while the other can output resolutions up to 1920 x 1200.
  • Increases your productivity by providing multiple displays
    Adding more displays to your workstation can be difficult, especially if your computer does not support MST or offer many external video ports. This USB to dual HDMI adapter features two video outputs, boosting your productivity by giving you more screen space to work from. With multiple displays you have the freedom to access multiple applications at the same time and reference material on one display while you compose on the other.
  • Maximizes your screen real estate with resolutions up to 4K
    One of the ports on this USB video adapter supports resolutions up to 4K at 30Hz, meaning you can connect a 4K monitor, HDTV, or projector to your computer, even if your laptop or desktop video card doesn't natively support 4K output. The USB to HDMI 4K adapter lets you extend or mirror your primary display onto an Ultra HD monitor or television, giving you the additional screen space you need to simplify multitasking and maximize your productivity.
  • Perfect for all of your business applications with USB 3.0 performance
    Using the high-bandwidth USB 3.0 interface, this USB 3.0 to HDMI adapter enables smoother scrolling through documents, higher resolutions and better overall performance than earlier USB adapters. This video adapter is intended to support all of your business applications including web browsing, e-mail, spreadsheets and presentations. You can also leave your system video card available for more demanding applications such as gaming or CAD design, while you use the USB monitors for reference material. The USB32HD2 is backed by a StarTech.com 3-year warranty and free lifetime technical support.
StarTech.com USB 3.0 to Dual HDMI Adapter, 1x 4K 30Hz & 1x 1080p, External Video & Graphics Card, USB Type-A to HDMI Dual Monitor Display Adapter Dongle, Supports Windows Only, Black - USB to Dual HDMI Adapter (USB32HD2) - adapter cable - HDMI / USB - TAA Compliant - 25 cm
Cable
Adapter cable - HDMI / USB
TAA Compliant
Max Output Resolution
3840 x 2160 - 30 Hz
Length
25 cm
Connector
USB Type A - male (input)
Connector (Second End)
2 x HDMI - female (output)
USB 3.0
4K30Hz (3840 x 2160) support
P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
Cable Type
Adapter cable 4K30Hz (3840 x 2160) support
Interface Supported
HDMI / USB
USB 3.0
Length
25 cm
64 MB memory
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Microsoft Windows 7 / 8.1 / 10 (32/64 bits)
Connector
9 pin USB Type A - male (input)
2 x 19 pin HDMI Type A - female (output)
WHQL, FCC, RoHS
TAA Compliant
6.6 cm
1.5 cm
56 g
Shipping Width
14.4 cm
Shipping Depth
20.7 cm
Shipping Height
3.8 cm
Shipping Weight
184 g
CX91 StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.29
CX91 StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter In Stock £77.49
CX91 StarTech.com USB 3 to HDMI w/ USB Hub In Stock £67.65
CX91 StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £35.80
CX91 StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £51.86
CX91 StarTech.com USB 3.0 to Dual HDMI Adapter In Stock £46.31
CX91 StarTech.com USB to Dual DisplayPort 4K 60Hz In Stock £85.53
CX91 StarTech.com USB 3.0 to HDMI VGA Adapter - 4K 30 - External Video & Graph In Stock £64.44
CX91 StarTech.com USB C to 4x HDMI Adapter- 1080p - USB Type-C to Quad HDMI In Stock £142.11
CX91 StarTech.com USB to Dual HDMI Adapter In Stock £69.03
