StarTech.com USB to Dual DisplayPort 4K 60Hz
Quicklinx: DXFLWS00 Mfr#: USB32DP24K60
10 In Stock
£80.35 ex VAT
£96.42 inc VAT
Connect two additional 4K 60Hz displays to your Mac or PC through a single USB 3.0 port. This USB to dual DisplayPort adapter lets you add two 4K 60Hz DisplayPort monitors to your Windows or Mac computer.
The adapter lets you use a single USB 3.0 port on your laptop to output dual 4K resolution at 60Hz to two independent displays. Simply plug the adapter into a USB 3.0 (5Gbps) port on your Windows or Mac system and connect your DisplayPort monitors to the adapter.
The adapter lets you enjoy the picture quality of Ultra HD video across multiple screens, even if your system doesn't natively support 4K video output.
With two UHD 4K displays, you can work more efficiently and accomplish more in the same amount of time. With each display delivering 4K performance, you can have four times the screen space compared to 1080p.
With multiple displays, you can output different content on each display at resolutions of up to 4096 x 2160p (60Hz). The dual DisplayPort adapter is ideal for business applications such as spreadsheets, word processors and web browsers. You can multitask and preview different data points across each display. For instance, you can calculate data on one display, write a report on the second display, and browse the internet on your laptops display.
  • Create a dual-4K 60Hz workstation
    The adapter lets you use a single USB 3.0 port on your laptop to output dual 4K resolution at 60Hz to two independent displays. Simply plug the adapter into a USB 3.0 (5Gbps) port on your Windows or Mac system and connect your DisplayPort monitors to the adapter. The adapter lets you enjoy the picture quality of Ultra HD video across multiple screens, even if your system doesn't natively support 4K video output.
  • Maximize your screen real estate
    With two UHD 4K displays, you can work more efficiently and accomplish more in the same amount of time. With each display delivering 4K performance, you can have four times the screen space compared to 1080p. With multiple displays, you can output different content on each display at resolutions of up to 4096 x 2160p (60Hz). The dual DisplayPort adapter is ideal for business applications such as spreadsheets, word processors and web browsers. You can multitask and preview different data points across each display. For instance, you can calculate data on one display, write a report on the second display, and browse the internet on your laptops display. The USB32DP24K60 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB 3.0 to Dual DisplayPort Adapter 4K 60Hz, DisplayLink Certified, Video Converter with External Graphics Card - Mac & PC (USB32DP24K60) - DisplayPort adapter - USB Type A to DisplayPort - 30 cm
DisplayPort adapter
4K60Hz (4096 x 2160) support
Length
30 cm
Connector
9 pin USB Type A - male (input)
Connector (Second End)
2 x 20 pin DisplayPort - female (output)
USB 3.0
DisplayPort adapter
Length
30 cm
14.2 cm
17.5 cm
3 cm
155 g
Connector
USB 3.0, FCC, RoHS, DisplayLink Plug and Display
Shipping Width
4.5 cm
Shipping Depth
15.5 cm
Shipping Height
13.4 cm
DXFL StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £13.28
DXFL StarTech.com Slim USB 3.0 to HDMI External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £22.64
DXFL StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC In Stock £48.92
DXFL StarTech.com USB 3.0 to 4K DisplayPort External Multi Monitor Video Graphics Adapter In Stock £61.54
DXFL StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £8.87
DXFL StarTech.com 1m 3.3ft DisplayPort 1.4 Cable In Stock £6.74
DXFL StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £13.72
