StarTech.com USB 3.0 SATA Hard Drive Docking Station SSD / HDD with integrated Fast Charge USB Hub
Quicklinx: 93K1WS00 Mfr#: SDOCKU33HW
Type: Storage controller
HD Size: 2.5, 3.5
Power Supply: Power adapter
  • Windows 8 (32/64 bits)
£48.48 ex VAT
£58.17 inc VAT
Dock your 2.5" or 3.5" SATA SSDs/HDDs and add USB Fast Charge Capacity in a stylish white docking station. The SDOCKU33HW USB 3.0 Dock with Fast Charge USB hub lets you easily connect and swap 2.5in or 3.5in SATA III hard drives (HDD) and solid state drives (SSD) through an available USB port. The enclosure supports UASP and delivers optimal performance with a USB 3.0 connection, but is also backward compatible with USB 2.0/1.1 host connections.
The Hard Drive Dock features a built-in 3-port USB 3.0 Hub that enables you to connect up to 3 additional USB 3.0 devices to your computer through the same USB host connection. One of the ports on the hub also has Fast Charging capabilities, that charges iPad and other mobile devices as effectively as through a wall plug. This Fast Charge Port has been specially designed for compatibility with a wide range of tablets and smartphones.
With support for UASP, the dock performs up to 70% faster than conventional USB 3.0, when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives.
With support for SATA I/II/III, large capacity drives (tested up to 4TB), and 2.5in or 3.5in hard drives this HDD/SSD docking station is compatible with virtually any SATA hard drive, and greatly increases the storage/backup capabilities of your computer. Plus, the dock features configurable power management, which reduces energy consumption and helps extend the life of your drives by avoiding unnecessary access.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in IDE hard drive into a SATA hard drive dock.
With uniform white design and sleek silver trim, the SDOCKU33HW will look great with your Apple Mac.
StarTech.com USB 3.0 SATA HDD Docking Station w/ Fast Charge USB Hub & UASP - storage controller - SATA 6Gb/s - USB 3.0
Storage controller - external
Bus Type
USB 3.0
White & silver
Expansion Bays
1 x hot-swap - 2.5" / 3.5" shared
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Product Material
Plastic, aluminium
AC 120/230 V
Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits)
7.2 cm x 13 cm x 5.5 cm
350 g
P/N: SVA12M5NA, USBDUP15, USBDUPE115, USBDUPE17
2.5", 3.5"
Host Bus
USB 3.0
Product Material
Plastic, aluminium
White & silver
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
ASM1053E / VIA812
Bays
1 x SATA 6Gb/s - SATA combo
1 x USB 3.0 - 9 pin USB Type B , 2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 9 pin USB Type A (power only)
1 x USB cable - external - 1 m , 1 x power cable - external
LED indicator, 1 USB 3.0 (powered), tested with up to 4TB 5400 RPM 3.5" hard drives, tested with up to 1TB 5400 RPM 2.5" hard drives, built-in 3-port USB 3.0 hub
Plug and Play, FCC, RoHS
Power adapter
AC 120/230 V
7.2 cm
13 cm
5.5 cm
350 g
5 °C
35 °C
20 - 80%
93K1 StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £3.30
93K1 StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.08
93K1 StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.16
93K1 StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £12.07
93K1 StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP In Stock £37.71
93K1 StarTech.com USB 3.0 / eSATA Dual Hard Drive Docking Station with UASP for 2.5/3.5in SATA SSD / HDD In Stock £62.23
93K1 StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £52.38
93K1 StarTech.com USB 3.1 Gen 2 Dual-bay Dock In Stock £80.75
93K1 StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £52.74
93K1 StarTech.com Dual-Bay SATA HDD/SSD Dock In Stock £50.40
HD Size: 2.5
HD Size: 3.5
