Turn a 2.5" SATA III or IDE HDD / SSD into an external hard drive that connects to your computer through USB 3.0 with UASP. The UNI251BMU33 Universal 2.5in Drive Enclosure lets you turn a 2.5in SATA or IDE hard drive (HDD) or solid-state drive (SSD) into a portable USB 3.0 storage solution.
This versatile enclosure offers a simple solution for re-purposing 2.5in HDDs and SSDs that are no longer in use into convenient external storage. Since the enclosure supports either legacy IDE or SATA drives, you can rest assured that you'll have the correct option on-hand when it's time to swap another drive in, without having to worry about compatibility.
To get the most from your SATA III drives and ensure maximum performance and speed, the UNI251BMU33 is enhanced with UASP support. When paired with a UASP-enabled host controller, the enclosure delivers transfer speeds up to 70% faster than conventional USB 3.0.
Perfect for carrying your external drive along with your laptop, the UNI251BMU33 is USB-powered, so you won't need to carry around an external power adapter. Plus, the enclosure features a small-footprint design, making it a great solution for on-the-go laptop and desktop users who want to add storage to their computer without taking up much space.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
- StarTech.com 2.5" IDE Hard Drive Enclosure - Supports UASP - Aluminum - IDE and SATA - USB 3.0 HDD Enclosure - External Drive (UNI251BMU33) - storage enclosure - ATA-133 / SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Black
- Expansion Bays
- 1 x internal - 2.5"
- Hard Drive Form Factor Compatibility
- 2.5"
- Interface
- Data Transfer Rate
- 5 GBps
- Supported Devices
- Hard drive, solid state drive
- Max Storage Devices Qty
- 1
- Product Material
- Aluminium
- Power Source
- USB bus
- 12.5 cm x 16 cm x 0.8 cm
- 150 g
- 2-year warranty
- Designed For
- P/N: HB30A3A1CFB, HB30A3A1CSFS, HB30A3A1CST, HB30AM4AB, PEXUSB3S2EI, PEXUSB3S3GE, PEXUSB3S7, USB3VDOCK4DP
- 2.5"
- Hard Drive Maximum Height
- 9.5 mm
- Host Bus
- USB 3.0
- Product Material
- Aluminium
- Black
Storage Controller
- Interface
- 5 GBps
- Supported Devices
- 1
- Processor
- JMicron
- Bays
- 1 x SATA 6Gb/s - SATA combo , 1 x ATA-133 - 44 PIN IDC
- Connections
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Included Accessories
- Screwdriver
- Cables Included
- 1 x USB power splitter cable - external
- USB powered, LED indicator, UASP transfer protocol, tested with up to 2TB 7200 RPM 2.5" hard drives
- Mounting Kit
- Included
- Plug and Play, FCC, RoHS
- Power Source
- USB bus
- Limited warranty - 2 years
- 12.5 cm
- 16 cm
- 0.8 cm
- 150 g
- 0 °C
- 60 °C
- 0 - 90%
- Designed For
StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External | In Stock | £28.42 |
StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP | In Stock | £36.81 |
StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power | In Stock | £49.04 |
StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power | In Stock | £57.93 |
StarTech.com 2.5in Aluminum USB 3.0 External SATA III SSD Hard Drive Enclosure with UASP for SATA 6 | In Stock | £23.45 |
StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M | In Stock | £8.41 |
StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power | In Stock | £22.58 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels | In Stock | £51.85 |
StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels | In Stock | £85.11 |
StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £11.93 |
StarTech.com 0.5m (20in) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £8.41 |
StarTech.com 15cm (6in) Short Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £6.86 |
StarTech.com USB 3.0 IDE / SATA Enclosure | In Stock | £25.51 |
StarTech.com Rugged Hard Drive Enclosure | In Stock | £35.75 |
StarTech.com USB 3.1 Enclosure for 2.5" SSD | In Stock | £29.35 |
StarTech.com USB 3.1 2.5 SATA Enclosure USB-C USB-A | In Stock | £32.26 |
StarTech.com StarTech.com Biometric Enclosure USB 3.0 to 2.5" SATA | In Stock | £64.78 |
