StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M
Quicklinx: 93DZWS00 Mfr#: USB3AUB50CMB
Length: 50cm
More than 50 In Stock
£8.46 ex VAT
£10.15 inc VAT
Connect a USB 3.0 Micro USB external hard drive to your computer. The USB3AUB50CMB SuperSpeed USB 3.0 Micro B cable provides a high quality connection to your Micro USB-equipped USB 3.0 devices.
The short 0.5m /1.5-foot cable length is perfect for close-range connections (e.g. connecting a portable hard drive to your laptop) and the lightweight, compact design fits nicely into any carrying case.
  • Reliable connectivity
    This USB cable is compliant with USB 3.0 standards, ensuring compatibility and efficient data exchange between devices.
  • High-speed data transfer
    With a data rate of up to 5 Gbps, this cable allows for quick and seamless file transfers, saving time during data management.
  • Durable construction
    The molded connectors provide added strength, reducing wear and tear from frequent use.
  • Flexible compatibility
    Featuring a 10 pin Micro-USB Type-B connector and a 9-pin USB Type-A connector, this cable connects a wide range of devices.
StarTech 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - USB 3.0 Micro B Cable - 1x USB 3 A (M), 1x USB 3 Micro B (M) 50cm (USB3AUB50CMB) - USB cable - Micro-USB Type B to USB Type A - 50 cm
USB cable
Shielded
Molded, 5 Gbps data rate
Cable Length
50 cm
Connector
10 pin Micro-USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: DKT30CVAGPD, S2510BPU337, S2510BU33PW, S251BMU313, S251BMU3FP, S251BPU313, S251BRU33, S251SMU33EP, S252BU313R, SLSODDU33B, SM2NGFFMBU33, SMS1BMU313, UNI251BMU33
USB cable
Shielded
American Wire Gauge (AWG)
28
Cable Length
50 cm
Connector
USB 3.0, RoHS
93DZ StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M In Stock £8.46
Length: 50cm
