StarTech.com USB 3.0 IDE / SATA Enclosure
Quicklinx: B27LWS00 Mfr#: UNI251BMU33
Type: Storage enclosure
HD Size: 2.5"
£23.09 ex VAT
£27.70 inc VAT
Turn a 2.5" SATA III or IDE HDD / SSD into an external hard drive that connects to your computer through USB 3.0 with UASP. The UNI251BMU33 Universal 2.5in Drive Enclosure lets you turn a 2.5in SATA or IDE hard drive (HDD) or solid-state drive (SSD) into a portable USB 3.0 storage solution.
This versatile enclosure offers a simple solution for re-purposing 2.5in HDDs and SSDs that are no longer in use into convenient external storage. Since the enclosure supports either legacy IDE or SATA drives, you can rest assured that you'll have the correct option on-hand when it's time to swap another drive in, without having to worry about compatibility.
To get the most from your SATA III drives and ensure maximum performance and speed, the UNI251BMU33 is enhanced with UASP support. When paired with a UASP-enabled host controller, the enclosure delivers transfer speeds up to 70% faster than conventional USB 3.0.
Perfect for carrying your external drive along with your laptop, the UNI251BMU33 is USB-powered, so you won't need to carry around an external power adapter. Plus, the enclosure features a small-footprint design, making it a great solution for on-the-go laptop and desktop users who want to add storage to their computer without taking up much space.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com USB 3.0 Universal 2.5in SATA or IDE HDD/SSD Enclosure w/ UASP - storage enclosure - ATA-133 / SATA 6Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
Data Transfer Rate
5 GBps
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
Product Material
Aluminium
Power Source
USB bus
12.5 cm x 16 cm x 0.8 cm
150 g
2.5"
Hard Drive Maximum Height
9.5 mm
Host Bus
USB 3.0
Product Material
Aluminium
Storage Controller
Data Transfer Rate
5 GBps
Supported Devices
1
JMicron
Bays
1 x internal - 2.5"
1 x SATA 6Gb/s - SATA combo , 1 x ATA-133 - 44 PIN IDC
1 x USB 3.0 - 10 pin Micro-USB Type B
Screwdriver
1 x USB power splitter cable - external
USB powered, LED indicator, UASP transfer protocol, tested with up to 2TB 7200 RPM 2.5" hard drives
Mounting Kit
Included
Plug and Play, FCC, RoHS
Power Source
USB bus
12.5 cm
16 cm
0.8 cm
150 g
60 °C
0 - 90%
B27L StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £23.00
B27L StarTech.com 2 Port Flush Mount ExpressCard 54mm SuperSpeed USB 3.0 Card Adapter with UASP Support In Stock £29.85
B27L StarTech.com 2 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA Power In Stock £41.11
B27L StarTech.com 4 Port PCI SuperSpeed USB 3.0 Adapter Card with SATA / SP4 Power In Stock £48.59
B27L StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £18.53
B27L StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £58.65
B27L StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £71.38
B27L StarTech.com USB 3.0 IDE / SATA Enclosure In Stock £23.09
HD Size: 2.5"
Price Range Ex VAT: 0 - 50
