StarTech.com USB 3.0 / eSATA Dual-Bay Trayless 3.5" SATA III Hard Drive Enclosure with UASP
Quicklinx: 9RKGWS00 Mfr#: S352BU33RER
Connect two hot-swappable 3.5" SATA III hard drives to your computer externally through USB 3.0 with UASP or eSATA. The S352BU33RER 2-Bay RAID enclosure lets you build an external RAID array with two 3.5" SATA hard drives, and connect to your computer through USB 3.0 or eSATA.
For fast performance and efficient data transfers, the enclosure supports SATA III transfer speeds - up to 6 Gbps when connected through eSATA. The versatile RAID enclosure can also be connected through USB 3.0, with support for UASP, performing up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
The external RAID enclosure features a hardware RAID controller, supporting JBOD, Spanning, RAID 0, and RAID 1 - to achieve greater drive capacity, or secure data redundancy. The RAID controller is also front mounted for ease of access when changing your RAID mode.
For fast and easy drive installation and removal, the dual drive enclosure features a convenient trayless system that eliminates having to mount and fasten your drives, saving time and hassle.
To ensure compatibility with your computer system, the S352BU33RER supports all of the leading operating systems, including: Microsoft Windows (8/7/Vista/XP/Server 2008/Server 2003), Apple OSX (10.9/10.8/10.7/10.6), Linux, and Google Chrome OS.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
StarTech.com USB 3.0 / eSATA Hot Swap HDD Enclosure with UASP - 2-Bay Trayless 3.5" SATA III (6 Gbps) Hard Drive Enclosure (S352BU33RER) - hard drive array
Hard drive array
USB 3.0, SATA 6Gb/s
0 (installed) / 2 (max)
Supported Drives
SATA-600
Built-in Devices
Led panel
Storage Controller
RAID (SATA 6Gb/s) - RAID RAID 0, 1, JBOD
Hard Drive
0 SATA 6Gb/s - hot-swap
Linux, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
AC 120/230 V
P/N: SVA12M5NA
Hard drive array
Enclosure Colour
Chassis
Built-in Devices
Led panel
0
Supported Devices / Modules Qty
2
Supported Drives
SATA-600
Storage
HDD Array External Interface
USB 3.0, SATA 6Gb/s
Storage Controller
RAID
Channel Qty
2
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
Hot-swap
0
Interface Type
SATA 6Gb/s
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5" shared
1 x eSATA 6Gb/s - 7 pin external Serial ATA , 1 x USB 3.0 - 9 pin USB Type B
1 x eSATA cable , 1 x USB 3.0 cable
FCC, RoHS
External power adapter
AC 120/230 V
5 °C
35 °C
20 - 80%
P/N: SVA12M5NA
9RKG StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
