Connect a VGA display for an extended desktop multi-monitor USB solution. The USB2VGA2 USB VGA Adapter turns an available USB 2.0 port into an external video card VGA port - providing high quality dual-display or multi-monitor capability that can be used in a variety of laptop or desktop applications to increase your productivity.
The device also offers the option of running up to five additional displays simultaneously (using five USB2VGA2 Multi Monitor External Video Cards). Each connected adapter can be used to further extend the desktop or mirror the image shown on the existing display - all without having to open the computer case to install an additional video card.
- StarTech.com USB VGA External Multi Monitor Video Adapter - High Resolution - Graphics adapter - Hi-Speed USB - external video adapter - SiS 315
- External video adapter
- Bus Type
- USB 2.0
- Graphics Engine
- SiS 315
- Max Resolution
- 1600 x 1200 (32 bit) / 1920 x 1200 (16bit)
- Interfaces Details
- VGA
- 5.1 cm x 11 cm x 2.4 cm
- 2-year warranty
- Bus Type
- USB 2.0
- Graphics Engine
- SiS 315
- Max Resolution
- VGA
Video Output
- Colours Max Resolution (external)
- 16-bit (64k colours)
- OS Required
- Microsoft Windows 2000/XP/Vista/7, Microsoft Windows Vista / XP / 7 (64-bit versions)
- Additional Requirements
- USB port
- Cables Included
- 1 x USB cable - 45.7 cm
- Software Included
- Drivers & Utilities
- FCC, RoHS
- 5.1 cm
- 11 cm
- 2.4 cm
- 90 g
- Limited warranty - 2 years
