Quickly and easily connect SATA and/or IDE hard drives through USB 2.0. This USB 2.0 to IDE/SATA Adapter Cable connects any standard 2.5in or 3.5in SATA or IDE hard drive to a computer through USB 2.0. The adapter lets you connect a bare drive with no enclosure, saving time and hassle.
The USB 2.0 SATA/IDE Adapter features LED indicators that allow you to easily monitor status and activity updates, and is designed for durability and reliability.
- StarTech.com USB 2.0 to IDE SATA Adapter - 2.5 / 3.5" SSD / HDD - USB to IDE & SATA Converter Cable - USB Hard Drive Adapter (USB2SATAIDE) - storage controller - ATA / eSATA - USB 2.0
- Storage controller - external
- Bus Type
- USB 2.0
- Black
- Interface
- ATA / eSATA
- Supported Devices
- Hard drive
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows Millennium Edition, Microsoft Windows XP, Microsoft Windows Vista
- 4.3 cm x 87 cm x 1.5 cm
- 51 g
- 2-year warranty
- Host Bus
- USB 2.0
- Black
Storage Controller
- Interface
- ATA / eSATA
- Supported Devices
- Hard drive
- 1 x ATA - 40 PIN IDC , 1 x ATA - 44 PIN IDC , 1 x SATA 1.5Gb/s - eSATA
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- FCC
- Power adapter
- OS Required
- Limited warranty - 2 years
- 4.3 cm
- 87 cm
- 1.5 cm
- 51 g
StarTech.com 24" Serial ATA Cable | In Stock | £5.26 |
StarTech.com 18in SATA Serial ATA Cable | In Stock | £4.42 |
StarTech.com 36in SATA Serial ATA Cable | In Stock | £5.68 |
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £5.36 |
StarTech.com 12in Latching SATA Cable | In Stock | £5.48 |
StarTech.com 18in Latching SATA Cable | In Stock | £3.94 |
StarTech.com 24in Latching SATA Cable | In Stock | £6.08 |
StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable | In Stock | £4.96 |
StarTech.com 6in SATA Serial ATA Cable | In Stock | £3.55 |
StarTech.com 12in SATA Serial ATA Cable | In Stock | £4.44 |
StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F | In Stock | £6.14 |
StarTech.com 6in Latching SATA Cable | In Stock | £5.08 |
StarTech.com 8in Latching SATA to SATA Cable - F/F | In Stock | £5.30 |
StarTech.com 12in SATA to Left Angle SATA Serial ATA Cable | In Stock | £4.80 |
StarTech.com 6in SATA to Left Angle SATA Serial ATA Cable | In Stock | £3.91 |
StarTech.com 6in SATA to Right Angle SATA Serial ATA Cable | In Stock | £3.85 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £9.23 |
StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable | In Stock | £24.61 |
StarTech.com USB 3.1 Gen 2 Adapter Cable | In Stock | £15.20 |
StarTech.com USB 3.1 Adapter Cable w/ USB-C | In Stock | £19.09 |
StarTech.com USB 3.1 2.5/3.5" SATA Adapter | In Stock | £27.56 |
StarTech.com USB C to SATA Adapter Cable | In Stock | £35.55 |
StarTech.com 18in Right Angle SATA Cable | In Stock | £4.36 |
