StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable
Quicklinx: 9MLPWS00 Mfr#: USB3S2ESATA3
£23.03 ex VAT
£27.63 inc VAT
Connect an eSATA storage device to a USB 3.0 port on your laptop or desktop. The USB3S2ESATA3 USB 3.0 to eSATA drive cable lets you connect any eSATA hard drive, solid state drive, or optical disc drive to your USB-enabled computer system - a great solution for computers that don't natively support eSATA, such as MacBook and Ultrabook computers.
To maximize performance and utilize the speed potential of your SATA 6 Gbps drives, the USB 3.0 to eSATA adapter is compatible with SATA revisions I/II/III and supports transfer speeds up to 5 Gbps through USB 3.0.
With support for Blu-ray/DVD/CD ATAPI / ODD drives and large capacity HDD / SSDs (tested up to 4TB) the USB to eSATA adapter cable is compatible with virtually any eSATA device, and can greatly increase the storage/backup capabilities of your computer.
The USB 3.0 to eSATA drive cable ensures a hassle-free connection with simple plug-and-play installation, plus the cable is the perfect length (1-meter, end-to-end) for easily accessing the rear panel USB ports on your computer.
  • Fast data transfer
    The adapter provides data transfer rates of 6 Gbps, enabling quick access to files and efficient data management.
  • Versatile compatibility
    Designed to work seamlessly with Mac systems, the adapter allows for easy connectivity of external storage devices.
  • Reliable construction
    Built to withstand a range of operating temperatures from 0°C to 60°C and humidity levels of 40 to 85%, ensuring stable performance in various conditions.
  • Integrated design
    The integrated design allows for a clean and organized setup, with a convenient length of 80 cm for flexibility in use.
  • Meets compliance standards
    This product is compliant with FCC and RoHS standards, ensuring environmental safety and reliability in usage.
StarTech.com 3 ft USB 3.0 to eSATA Adapter - 6 Gbps USB to HDD/SSD/ODD Converter - Hard Drive to USB Cable (USB3S2ESATA3) - storage controller - eSATA 6Gb/s - USB 3.0
Storage controller - external
Bus Type
USB 3.0
eSATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
1
2.5 cm x 80 cm x 1 cm
137 g
Host Bus
USB 3.0
Storage Controller
eSATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
1
ASMedia ASM1153E
1 x eSATA 6Gb/s - eSATA
1 x USB 3.0 - 9 pin USB Type A
1 x USB cable - integrated - 80 cm
FCC, RoHS
2.5 cm
80 cm
1 cm
137 g
60 °C
40 - 85%
9MLP StarTech.com 2 port PCI Express SuperSpeed USB 3.0 Card with UASP Support - 1 Internal 1 External In Stock £27.08
9MLP StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.16
9MLP StarTech.com 4 Port PCI Express PCIe SuperSpeed USB 3.0 Controller Card Adapter with UASP In Stock £34.16
9MLP StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - Black In Stock £18.86
9MLP StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - LP4 Power In Stock £22.36
9MLP StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 2 Dedicated 5Gbps Channels In Stock £51.61
9MLP StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable In Stock £8.11
9MLP StarTech.com 2 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter with UASP - SATA Power In Stock £19.21
9MLP StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable In Stock £23.03
9MLP StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.31
9MLP StarTech.com CFast Card Reader - USB 3.0 In Stock £22.18
9MLP StarTech.com CFast Card Reader - USB-C In Stock £28.14
9MLP StarTech.com USB 3.0 to eSATA HDD/SSD/ODD Adapter Cable – USB-C In Stock £24.21
